Projects Quain Stott Willys build
Discussion in 'The Hokey Ass Message Board' started by Quain Stott, Aug 27, 2012.
  1. Quain Stott
    Quain Stott
    I've been slack on finishing this build thread so here's a few pic of the hammering out of the master cylinder cover.[​IMG]
  2. Quain Stott
    Quain Stott
    A little more hammering[​IMG]
  3. Quain Stott
    Quain Stott
    More hammering then a little dolly work for the lip and then a few p***es on the english wheel.[​IMG]
  4. Quain Stott
    Quain Stott
    not quite finished I ran out of time needs more detail work but that's the easy part I'll do that one day when I'm just fiddling around.[​IMG]
  5. Quain Stott
    Quain Stott
    Another angle I did this because I used an aluminum master cylinder and that just won't get it on a period correct G***er so I tried to hide it. [​IMG]
    Mtn Goat likes this.
  6. 1arock
    1arock
  7. Noland
    Noland
    great Willys build. just found it. Keep up the good work.
  8. My thoughts exactly! Wow :D
  9. Quain Stott
    Quain Stott
  10. Cool piece, Quain. What did you have in mind for under the hood?
    We're doing a "frozen snot" 36 Ford up pretty much the same way here at the school, so I'm keeping an eye on this one... ;)
  11. Nitrobaron
    Nitrobaron
    Great build thread, thank you for sharing, I learned a lot, and some times it is just the seamingly simple things that prove to be the most enlightening.
    Can you give some details on the small block, cubic inches, compression ratio, and I am curious what fuel are you running?
    That thing sounds great in the videos!!!!! Small block and 4 speed, can't beat it.
    Thanks
  12. Quain Stott
    Quain Stott
    The car has been finished for about a year some of my buddy's talked me into doing the build thread after it was finished. Anyway it has a 406 sbc with old school mechanical fuel injection there's a lot of videos on you tube of it some in car stuff that's cool.
  13. Quain Stott
    Quain Stott
    It's a 406 sbc with 15 to 1 compression the pic in my avatar is of the engine compartment. I run C 14 racing fuel it runs and sounds better on alcohol but our rules won't allow that.
  14. AHotRod
    AHotRod
    Great to see new updates Quain !
  15. HOTRODPRIMER
    HOTRODPRIMER
    Quain,you never cease to amaze me. HRP
  16. Quain Stott
    Quain Stott
    I got so pumped up with Cromers car build I haven't took time to post on mine.
  17. Quain Stott
    Quain Stott
    Here you go it's real simple just a 1/8' 4130 C/M plate bracket (3/16' if you use mild steel) with a bolt and bushing on the top and bottom of spring leave a little room between the 2 bushings and about 1/16' on the brackets for the spring to slide. if you are not going to use a pan hard bar you might want to brace the brackets from side to side. Note I drilled extra holes for ride height adjustment[​IMG]
  18. swade41
    swade41
    from Buffalo,NY
    Ha ha, I just went through this whole thread to see what you were running and here it is on the last page...lol The wheels up launch and half way down the track before settling down video from the Moonlighter thread had me wondering.
  19. Quain Stott
    Quain Stott
    Swade41 maybe now that I'm finished with cromers car and some of my other projects I can finish this build thread.
  20. Inland empire hot rods
    from so cal
  21. jammersspeed
    jammersspeed
    from herman mn.
    i have a gl*** willys body for one of my next builds... looking forward fot the rest of the build thread!
  22. Orange45
    Orange45
    from Liberty sc
    What style trans is in the car? Is it a Hightower
    Style or Jericho style. Thanks
  23. Quain Stott
    Quain Stott
    It's just a stock big gear Jerico 2.98 low with 4'88 in the rear.
  24. Orange45
    Orange45
    from Liberty sc
    Thanks for the info. I'm a cheapo how do the gm
    4 speeds do. Or do they break? Sorry for the questionnaire.
    Thanks
  25. Quain Stott
    Quain Stott
    They will brake if you have much power
  26. HOTRODPRIMER
    HOTRODPRIMER
    You won't be doing this with a stock GM 4 speed transmission.
    Quain is in the far lane. HRP
    <iframe width="640" height="480" src="http://www.youtube.com/embed/CTuhK3WoQSs?rel=0" frameborder="0" allowfullscreen></iframe>
  27. Future Stock
    Future Stock
    Love it, and can't wait to see a p*** with The Moonlighter in the other lane.
  28. Orange45
    Orange45
    from Liberty sc
    Thanks for the replys and info. Love the car.
    And enjoyed sat seeing all the g***ers
  29. captmullette
    captmullette
    damn that's carrying the front end and shifting some gears......
  30. II FUNNY
    II FUNNY
    That video is awesome. I can't wait to see that car run in person.
    "MELTDOWN DRAGS"
    July 20, 21 2013 at Byron Dragway Byron Ill.
    www.meltdowndrags.com
