Quality Choke Cable
Discussion in 'The Hokey Ass Message Board' started by boutlaw, Jan 24, 2012.
  1. boutlaw
    boutlaw
    My Autozone POS choke cable requires constant attention as there is not enough friction in the pull to keep it from vibrating out and choking the engine. I checked Advanced and they have the same crappy cable. I have not checked NAPA. Can some one please direct me to a quality choke cable that actually works properly, hopefully someting made in the USA. New manual choke carbs (only one has a choke cable). Its the cable thats the problem as the choke never vibrated on until I installed the cable. If I can't find a quality Auto cable, I can purchase a pull cable from Aircraft Spruce, they're just generally more expensive since its an aircraft part. Thanks
    BOutlaw
  2. Dave Downs
    Dave Downs
    from S.E. Penna
    Mine's from NAPA, no problems, was about $15-20 IIRC
  3. kwoodyh
    kwoodyh
    I robbed mine out of a 1966 C-10 truck.
  4. boutlaw
    boutlaw
    I'll check NAPA since you seem satisfied with the quality. Thought of Pull-a-Part but seems everything at the local one is FI and would not have a choke cable. I hate rebuying parts because of poor quality. Thanks guys.
  5. dreracecar
    dreracecar
    from so-cal
    Aircraft Spruce has high quality cables aqnd also ones that twist lock
    5' t handle 1/4turn lock p/n05-15000 $24
    those people that package cables for autoparts stores seem to have a competition on who can wrap the cable the tightest before they package it .
  6. Relic Stew
    Relic Stew
    from Wisconsin
  7. handyandy289
    handyandy289
    from Georgia
    Quick fix. Pull the cable out a little ways and put a slight kink in the wire and put it back in. The friction should solve your problem.
  8. Another vote for NAPA cables. Running 2 of them on the '47 for throttle & choke and they are holding up fine.
  9. boutlaw
    boutlaw
    I'm gonna put a kink in the cable per handyandy before I drive the coupe to NAPA tomorrow to check out their cable. If the kink "don't kink" and hold, and the NAPA cable doesn't resemble the Autozone cable, I'll get the NAPA cable. If that fails, I'm calling Aircraft Spruce. I appreciate all the input and figure the NAPA cable will get it done. Thanks guys
  10. Shopking
    Shopking
    from central Pa
    I've used the NAPA cable this winter.The package had made in US.The cable works fine.
  11. I have used some good motorcycle cables. Try one of your local shops and see if they have anything that might work
  12. Bruce Lancaster
    Bruce Lancaster
    NAPA also catalogs one with the twist-lock feature. Stuff like this is in a catalog entitled something like "Supplies and accessories"...if you can gettem to give you one, it is full of little goodies that cannot be found by the "...and does this have power steering" guy who is probably running the counter now that old Edgar who knew everything has dropped dead.
  13. chaos10meter
    chaos10meter
    from PA.
    I have also used a pump pliers and smashed the cable housing a little bit to tighten it .
  14. Dane
    Dane
    from Soquel, CA
    Me too, Aircraft Spruce has lot's of cool stuff. Check out some of their 135,000 candle power landing lights that can be fit into the high beam bucket on 4 headlight cars. :D
  15. Judd
    Judd
    Brad just send that coupe down here i'll take the choke off I won't need it ! Dane can I use the lights without a second generator? I'm tired of these guys with their under the bumper driving lights blinding me and need some counter attack. LOL.
  16. atomickustom
    atomickustom
    I'm with chaos10meter: crimp the housing a little bit at a time near the knob until you get the friction you need.
  17. scottybaccus
    scottybaccus
    Tractor supply has industrial control cables for cheap.
  18. boutlaw
    boutlaw
    Hell Judd, I can't send it your way, you'd be racing it this weekend. You'll need a carhauler to haul all your racecars. How's the 406 Galaxie coming?
    I've bought from Spruce for years, just not as much since I sold the 206. You get used to quality aircraft parts and when I started hot rodding again, I was/am very disappointed in the lack of quality in just basic auto parts. Lotta junk out there.
    Brad
    31 FE coupe
  19. squirrel
    Yup, get one out of an old truck, make sure it's an original, and in good condition.
  20. XXL__
    XXL__
    You guys have got to stop posting stuff like this! Yesterday, it was a $2M tubing bender that I've got to have. Now it's 27 different things from this place! I don't have the money. And don't actually need any of it... but it's too cool to pass up!
  21. Genuine Holley brand cable, you can get them thru Jeggs, TR
