I read in a peterson published how too book...that youcan "soak" your axles fr a couple days covered in dry ice..and then let them thaw in room temp. Says yhey will be considerably harder to twist and break. Anyone ave experience with this trick?
I read the same thing,back in the 70's. The process has been developed since,that is basically what they do for Cryogenic treatment. Quite common now.
I heard Viagra works in like 30 minutes.May try that. Check your PM's. I sent the links we talked about.
[ QUOTE ] I heard Viagra works in like 30 minutes.May try that. [/ QUOTE ] When it wears off the wheel will fall off and leave a grease spot
