Question about air bag install
Discussion in 'The Hokey Ass Message Board' started by THE BRONSON, Jul 9, 2009.
  1. THE BRONSON
    THE BRONSON
    Had a couple of questions about air bag setup, I dont know much about setting up my bags so any help would be great.
    1. I have (6) GC 350 extreme air valves that Im looking to install but was wondering how you wire these. If I take off the connector from the coil do I just screw the wire into the DIN connector, and also what kind of wire is best used for this setup?
    2.What do the air valves get wired too? Do they get wired to the control switch? Not sure how this is setup, Ive searched online but have come up with nothing.
    Does anyone have any setup diagrams for the wiring and plumbing or does anyone know where I can locate one or the other? Like I said Im setting my ride up with
    6 air valves, two on each bag in the front and one on each in the rear. Im not looking to make my ride dance or anything just raise/lower for correct rideability.
    Im a little lost in the dark when it comes to suspension. Thanks in advance, cheers. :confused:
  2. Reds 29
    Reds 29
    I would get two more valves so you have two for each corner. One for up and one for down. It's better to have a set for each corner, you won't get body lean because of air transfer when cornering. For directions for installation check suicidedoors.com web site. They have wiring diagrams,air line diagrams, etc. in their installation instructions. Also several members of the hamb sell air suspension parts and could help you. Kustombuilder, is one and the another one escapes me right now. I've got CRS. Also do a search here on the hamb, lots of info available. Don't worry about the **** some people will give you about air bags, low cars are traditional, how you get it there is your choice. Build what you want.
    Red
  3. tjelwood
    tjelwood
    from oklahoma
    Reds 29 you beat me to it. Suicidedoors.com is where I got all of my stuff for my truck and car. A ton of info on there site as far as diagrams and other good info.
  4. THE BRONSON
    THE BRONSON
    Thanks Red for the info, Ill give suicidedoors a try.
