Hot Rods Question about air compressors
Discussion in 'The Hokey Ass Message Board' started by flatford39, Oct 4, 2018.
  1. BamaMav
    BamaMav
    from Berry, AL
    I've got a DeVilbiss 60 gallon upright that I bought about 20 years ago. I bought it at a tool outlet place in Cullman AL, I think it was made in MS or TN. It's been a good one, many days it has ran all day long while sanding or grinding. It still has the original belt on it! I've got to put a new drain **** in it, the original one has started leaking air.
  2. flatford39
    flatford39
    https://www.northerntool.com/shop/tools/product_211720_211720
    Anyone have an opinion on this one. I paint and use a small blast cabinet as well as a pressure pot blaster. They claim it's 18CFM. Should be enough for my needs.
    I am a hobbyist and not a full time shop doing multiple things at once. It's just me and whatever I am doing at the time. I am sure it will keep up with my painting needs not to sure about the sandblasting.
    Thanks for all the advice so far. It is appreciated.
    Boneyard51 likes this.
  3. Fortunateson
    Fortunateson
    I have a DeVilbiss from my local tire shop built in Canada. They said it kept blowing capacitors. I was about five years old so they bought a new one. I bought theirs for $400 and had it serviced for $200. 7.5 HP and 150 or so PSI. I'm a happy camper.
    flatford39 and dirty old man like this.
  4. Boneyard51
    Boneyard51
    That one should do most anything in a one man shop. I like more max psi, makes your air tools work! I ran 160 in my shop.
    Bones
    flatford39 likes this.
  5. dirty old man
    dirty old man
    I don't trust those 3450 rpm compressor motors, and 950 rpm compressor isn't gonna last either. Look at the reviews, they aren't exactly good either.
    Boneyard51 and flatford39 like this.
  6. 1934coupe
    1934coupe
    Yes I have an opinion, it turns too fast as far as I'm concerned that's how they get the rating of 18 cfm. I have a TIP pressure blaster also and I did sandblasting it uses a lot of air and runs almost continuously.
    I find that the faster they run the hotter the air and then the condensation is greater. Now this is just my opinion and experience.
    Pat
  7. flatford39
    flatford39
    https://www.northerntool.com/shop/tools/product_200350475_200350475
    You guys are great and are backing up all my concerns. Thank you. I like this one better as it's two stage and made here in the USA. I agree with all of you about the 3450RPM motors but that seems to be the nature of the beast in a new compressor purchase.
    Just to put this all in to perspective the only reason I am asking about this is I lost my motor on an ancient Curtis air compressor. Probably a 60 year old machine. Almost as old as me (ha ha ha). I am just concerned about putting money into a 60 + year old pump.
    I think I might have just answered my own question.
    Thanks again.
  8. Boneyard51
    Boneyard51
    Like I said ,will this compressor do the job? Yes, and in a one man hobby shop it would last a long time. Is it the best compressor on the planet? No. I too, was concerned about the high speed motor, but liked mentioned, that’s kinda the way they do things now.
    Repowering an old compressor is a gamble. Not that it’s not the right thing to do, but sometimes it’s best to buy new, so that you don’t have to work on the stuff you use to work on your stuff.
    You want to drop about three times that amount, you can get a real commercial compressor that has it all.... but your pocket book is going to hurt.
    Just my .02
    Bones
  9. Andyman
    Andyman
    I spent extra and got a Quincy, it'll be going when harbor freight is long gone.
    Andy
  10. Budget36
    Budget36
  11. While that link is wrong (seems I didn't notice the decimal point in the hp...:oops:), motors have shrunk some over the years. You have to go over 10hp before they get real size these days unless they're explosion-proof or another specialty frame, although the low-rpm single-phase motors are a lot heavier and expensive than the more-common 3450 rpm versions.
    A now-deceased neighbor I used to have had an ancient (1903 IIRC) 5HP, single-phase motor and pump sitting loose in a concrete shed, a relic from when it was an active farm. The motor, not including the pump, was roughly the diameter of a modern large garbage can and its case was about 2/3 as long. I don't know what it weighed, I couldn't even budge it by myself. I've seen 50hp motors that were barely that big.
