question about carb adjustment?
Discussion in 'The Hokey Ass Message Board' started by dannyego, Sep 2, 2010.
  1. dannyego
    dannyego
    If the adjustment screw on the driver side of the car does not affect idle when it is turned all the way in or all the way out is it a carb problem or possibly a vacuum leak at the intake? I havent found a vacuum leak at the intake and I have ruled out a vacuum leak everywhere else. I have cleaned out the adjustment holes so it is not a problem with it being clogged. It is an edelbrock carb if that helps. The reason I ask is a rebuild kit is $50,and with a baby who needs super allergic formula every little bit helps:)
  2. 1952henry
    1952henry
    What kind of carburetor?
  3. dannyego
    dannyego
    Edelbrock 1405
  4. which screw? pictures?
  5. merf
    merf
    from new joisey
    If one screw is out too far the other won't react. Screw the one in that seems to work until it idles rough then try it. If that doesn't work it sounds like you have **** in the carb.
