Hot Rods Question- Center of fan in relation to radiator ?
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Dec 8, 2016.
  1. blazedogs
    blazedogs
    Been told the best location for the center of the water pump pulley and fan in relation to the radiator is toward the center or bottom of the radiator for the best cooling. The engine sits low in the frame in my Model A .Now the center of the rigid fan is no where near the best location. Without changing the motor mounts and engines location what are my best options. Hook it all up and try it ,go with a electric fan with shroud or what - any suggestions ? Gene
  2. BJR
    BJR
    Try it as is, and if it over heats make a shroud for it.
    firstinsteele and prewarcars4me like this.
  3. Texas Webb
    Texas Webb
    Do you have a shroud now?
  4. 325w
    325w
    Cooling works best at the top I thought. Maybe try the Zip water pump relocation. Raises the pump 5 are so inches higher. Works great on my 32.
    lurker mick and Hnstray like this.
  5. big duece
    big duece
    from kansas
    ***uming its a sbc....
    Hnstray likes this.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Gene, pictures would help, but past that, run it and if it cools, great. If it doesn't, put on a shroud or go electric..
  7. blazedogs
    blazedogs
    Sitting out here looking at it , Not going to be nostalgic looking but going to go with a electric fan with shroud
    My luck will run hot and I will have to back up I'm getting old and lazy Yup SBC
    prewarcars4me likes this.
  8. AVater
    AVater
    That's what I thought
  9. HOTRODPRIMER
    HOTRODPRIMER
    Regardless of whether you use a mechanical or electric fan the ideal location is to center fan in the middle of the radiator.
    If you want to use a mechanical fan Zips riser will get you where you need to be if using a sbc...if your using a sbf ,snow white offers a riser also.
    Want a electric fan there are a lot of them to choose from. HRP
  10. jimcolwell
    jimcolwell
    from Amarillo
    The hot water go's in the top of your radiator.
    Mount the fan high in the middle of your radiator.
    I like the cooling concepts fan / shroud combo.
    A sbc needs to run 200 degrees for complete emission burn.
    If the radiator doesn't puke water run it.
    The only thing that will hurt your engine is dry spots in the water jacket.
