question for the '32 5W experts
Discussion in 'The Hokey Ass Message Board' started by GaryN, Feb 23, 2013.
  1. GaryN
    GaryN
    I'm in the process of redoing the body on my coupe and I'm wondering what the best method of attaching the rear tail pan is? It looks like it was just bolted in originally. I'm not sure if the factory leaded the seam or not. When I built the car 40 years ago it was just bolted in and seam sealed but that didn't hold up due to body flex. If the factory didn't lead the seam, how are you supposed to keep the water out?
  2. alfin32
    alfin32
    from Essex, Ma.
    Mine's bolted, with no sealer.
  3. Uptown83
    Uptown83
    same as alfin32
  4. X3 on bolts - no sealer.
  5. X4 no sealer. Old cars leak some water.
  6. X5,,bolted,,no sealer. HRP
  7. original hotrod 32
    original hotrod 32
    from england
    x6 bolts drill little hole for water drain safeside
  8. X7 no sealer just bolts
  9. GaryN
    GaryN
    Any thoughts on welding the seam solid? Good? Bad? The top filler between the roof and trunk opening looks like it was welded and leaded originally where it meets the quarter panels..
  10. alchemy
    alchemy
    If you need to seal it, but a bead of sealant down in where the bolt holes are, not out on the surface. Then it won't show and if it flexes and cracks the paint it won't look bad.
