Question for the "aero-savy" guys!!
Discussion in 'The Hokey Ass Message Board' started by BRENT in 10-uh-C, Aug 28, 2007.
  1. BRENT in 10-uh-C
    BRENT in 10-uh-C
    Which body & fender package is more aerodynamic at say 60 mph? A 1928-29 Coupe or a 1930-31 Coupe, ...and specifically why (i.e.: what part(s) makes it dirty or cleaner between the two)?
  2. mustangsix
    mustangsix
    I would guess that the drag coefficient is roughly the same on the two, but the early body might be slipperier due to smaller frontal cross section. Either one has more drag than a brick, especially with fenders attached. :)
  3. FordF1
    FordF1
    from Ottawa
    I've wondered the same thing. The 29 fenders come down further than a 30. I would think that the 29 fenders have a higher low pressure area created from the fender travelling down the road. The shorter 30 fenders would have more air underneath them so there would be less of a low pressure above the fender. Maybe it's not as much a question of drag, but the whole front end "lifting" and losing steering control at high speed (~160km/h).
  4. pitman
    pitman
    The 30-31's are less sharp in their radii, being broader but creating less pressure differential. The cowl area is improved from the step feature in the 28-29. Brick is apropos as the windshield pushes like no tomorrow above 70mph.
  5. greasel
    greasel
    from Fresno, CA
    you're supposed to use a turbo or blower to make up for aerodynamic efficiency, aren't you?
  6. BRENT in 10-uh-C
    BRENT in 10-uh-C
    :rolleyes: ???? mmmmmmm...
    ..........Not in V4/VGC anyway.:D
  7. SUHRsc
    SUHRsc
    brent....
    are you allowed to do any "work" to the fenders?
    maybe extending the front like later fenders would help to get the air around them and keep from the "scoop" effect?
    whats the rules on the top? chopped? slant window cowl?
    roadster with a hard top?(one existed in the past, red and white i believe?)
    what about tires? getting the tires as close to the fenders would help cut down on the air actually hitting the inside of the fender and getting them out toward the outside as far as possible with wheel discs i would think would help push the air around the fenders
    how about some strategically shaped "oil-water-gas" cans on the running board to direct air around the rear fenders?
    and make sure your door handles arent sagging :D
    good luck with it brent
    Zach
  8. KATFISH
    KATFISH
    I've wondered about this all my life,
    keeps me awake most night's..
    Just one of life's mysteries..
    You need a Lambo
  9. Bruce Lancaster
    Bruce Lancaster
    One way of getting some numbers is readily available...problems would include equalizing tires, drag in gear train, and the probable aerodynamic changes caused by hight of fender to wheel from spring sag...
    Seems like a year at your place should give you access to a number of coupes...so equalize the above factors as much as possible and do some coast-down tests.
    Runnemup to a standard speed...shift into neutral...measure time and distance of coast-down. Not perfect due to the number of possible variables, but cheaper than building a wind tunnel...
  10. dana barlow
    dana barlow
    from Miami Fla.
    Enough HP and a brick can fly,is all we need to know.
  11. BRENT in 10-uh-C
    BRENT in 10-uh-C
    Now THAT's an idea??
  12. Bruce Lancaster
    Bruce Lancaster
    Building the wind tunnel?? Chicken coop with end walls and chickens out, surplus 3310 motor and propeller, wire throttle to "combat emergency" setting, chain the car to your bathroom scales. A snap.
    The coast down is a legit engineering test too, basically just time or distance for dead stick coast from X MPH to Y MPH. Obviously it measures all drag together, so main need is to get tire and geartrain drag as equal as possible.
    I think it gives a reasonable test of what amounts to negative horsepower...
  13. Bruce Lancaster
    Bruce Lancaster
  14. Bruce Lancaster
    Bruce Lancaster
    Note from that the two schools...level test is basically a coast to stop, hill test adds in influence of gravity...
  15. pitman
    pitman
    Coast down offers a sound approach.
  16. Cword
    Cword
    FWIW The 2004 record setter ran a '31
    1931 V4/VGC Lickity-Split Racing
    94.088 mph p***
  17. BRENT in 10-uh-C
    BRENT in 10-uh-C
    Yes he did ...with a borrowed engine. --and in 2006 and 2007 he did ???
    Not to take anything away from Pete because he already has a car built --and I currently don't-- but for some reason in my mind, a 28-29 Coupe seems like a better choice. One doesn't know whether he started with a 30-31 because he already had one, ...or whether he felt there was an advantage. I don't know why I think the '28-29 would be the choice but maybe it is because you seem to see more '28-29 roadsters over '30-31 roadsters. If the roof-line is similar between the two coupe bodies (other than the width) then the nod would seem to go '28-29.
    I might further say that Pete's record has no "immediate worries" from my camp as I am planning on Maxton since that is on my side of the world. Might even do a roadster in lieu of the coupe:confused:
    So confusing. Already have a ****nal of V4F and V4 banger bullets to run. Just tired of traveling 400+ miles to go run with A.A.R.A . Kinda ready for a new chapter and a different challenge I suppose.
    Again, thanks everyone for the help! I appreciate your thoughts!!
  18. Cword
    Cword
    The pictures I had were from 2004, that 98 was his best speed that year. His record then was around 94 mph. According to this years record book in 2006 he moved it to 107.778
    I don't recall even seeing the car this year.
    My gut feeling is in agreement with you that the 28/29 seems like it should be slipperier. I have a 28 roadster, my dad has a 30. my roadster definitly feels narrower than his. I've never made measurement to back up that feeling though.
    I do also remember setting a 30 front fender on my car back when I built it and seeing that it fit wider than the 28.
