Question for the machinist type
Discussion in 'Off Topic Hot Rods & Customs' started by Roothawg, Feb 28, 2025.
  1. Roothawg
    Roothawg
    I would like to make a custom plate engraved or milled with a relief carving.
    Would a guy need to hire a cnc machinist to do this or what would be the best route for this? It's a fairly small plate, maybe 5"x10".
    It's going to replace this one.
    All of this will be polished and the relief will be painted to match body color.
    Just trying to figure out how to go about this.
  2. swade41
    swade41
    from Buffalo,NY
    You can do it yourself if you own a drill press, I've did several pieces this way, multiple shallow p***es.
    Here's a video I made
    Sand it when your done
    Roothawg, bobss396, Deutscher and 2 others like this.
  3. onetrickpony
    onetrickpony
    from Texas
    They do some amazing stuff now with 3d printing
    jimpopper likes this.
  4. RodStRace
    RodStRace
    You can attack it a couple ways. You can have the design CNC machined, engraved or laser etched into metal. (Subtractive)
    You can have a new plate of plastic or metal 3D printed to the design you want. (Additive)
    These will be at different price points, depth and clarity. It's up to you to determine value and quality that meets your standards.
    You can also DIY as @swade41 showed. I will mention that drill presses are not designed for heavy side loads, so either use a big ol beast or consider the cheap one a throwaway after cutting to the side. I've seen some pretty damn interesting stuff done with routers, too. If you don't mind a shallow design, you could even mask and blast. Again, a very light design can be done using masking and acid.
    Or you can learn a new trade.
    www.youtube.com/watch?v=PY2chD5xYoc
    Roothawg likes this.
  5. SS327
    SS327
    You can even use a wood router and wood bits with lots of WD40.
    Roothawg, Okie Pete and Deuces like this.
  6. Deuces
    Deuces
    They even cut steel....
    SS327, Roothawg and Okie Pete like this.
  7. Okie Pete
    Okie Pete
    IMG_7802.jpeg I used a Dremel tool to do this .
    deathrowdave, SS327, Sharpone and 3 others like this.
  8. mohr hp
    mohr hp
    from Georgia
  9. bobss396
    bobss396
    I worked in one shop, we had a few pantographs, I would make up bigger templates to do real small work.
    We had 2 old Gortons and some Swiss made one. This shop had no NC or CNC. If we had a big housing that needed an o-ring groove, that was how we did it.
    One guy carved out a horse head and a name plaque for a riding stable, it looked mint.
    Deuces and Roothawg like this.
  10. Roothawg
    Roothawg
    My boss owns a sign shop side business. I called him last night to see if his cnc router would do aluminum. He said no problem, so I will have him make a few. It costs the same to make 10 as it does one. Thanks for the input guys. I’m always intrigued at what hambers know!
    bobss396, SS327, Okie Pete and 3 others like this.
