Question? interior
Discussion in 'The Hokey Ass Message Board' started by Rustem, Feb 2, 2012.
  1. Rustem
    Rustem
    Who knows?
    in the doorway, at the front door, is an embedding of pressed cardboard, it is necessary to secure Windlace Set.
    My board looks very bad.
    That can be used to replace the board?
    Forgive me if I did not properly named these parts.
  2. chopolds
    chopolds
    from howell, nj
    It's called a tacking strip. You can buy it, though modern versions are a hard plastic. You can also replace it with wood cut to fit. Takes staples better.
  3. 56premiere
    56premiere
    do what chopolds said ,use wood.pine will last and splits less than hard woods.i been doing inteririors for 47 years and never had any go bad.and at my age wood is always good!
  4. Rustem
    Rustem
    Yes thanks, I also thought the tree would work.
