Technical Question on 1932 Ford cowl vent gasket
Discussion in 'Traditional Hot Rods' started by cmusser, Nov 4, 2025.
  1. cmusser
    cmusser
    I purchased a new gasket (Vintique #B-700616), and it is so thick it makes my cowl vent look bad sitting above my cowl so much. Does anyone know of an alternative that is thinner? I tried to cut this one down with a razor blade but it just got worse as my cut wasn't straight.
    I appreciate any good/helpful suggestions.
  2. flamedabone
    flamedabone
    I hit the hardware store for weatherstripping that is the width and thickness I need. I have never been able to get an original style gasket to do anything other than what you are experiencing. I kind of thought it was just me...
    -Abone.
  3. beater32
    beater32
    Same
    Tow Truck Tom likes this.
  4. Motordr32
    Motordr32
    No one makes a cowl vent gasket the correct thickness. I used an end mill to machine a groove in a piece of aluminum to the correct thickness or depth. Use that to support a few inches of the gasket.Then I used a razor blade to remove the excess material.
    19Eddy30 and Happydaze like this.
  5. alchemy
    alchemy
    Can you sand the gasket thinner on a belt sander? Or use a hand grinder?
    ct1932ford likes this.
  6. nochop
    nochop
    from norcal
  7. glennpm
    glennpm
    I reduced the thickness on mine with a hand held sander the type that takes a sheet of paper and clamps the ends.
  8. ct1932ford
    ct1932ford
    I sanded mine down on belt sander like alchemy suggested.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I just lucked up with my gasket, it fit like a glove but I got mine from Bob Drake.
  10. cmusser
    cmusser
    Hey guys, thank you for all the responses, I really appreciate it. I'm thinking I will trying sanding process with my next Vintique seal since several of you have done this with success. I tried cutting it down with a razor knife and went too far in a couple of spots and ruined it. I'll give it a shot (and take my time) Thanks again!!
  11. tubman
    tubman
    Why would you buy (and modify) another Vintiques piece when the one from Bob Drake seems to fit?
    It looks like he has them in stock.
  12. woodiewagon46
    woodiewagon46
    from New York
    The one I got from Bob Drake fit like Henry made it.
  13. Kiwi 4d
    Kiwi 4d
    I guess people keep buying the inferior vintique seals and end up throwing them in file 13 so vintique keep making inferior seals. They don’t care if they fit or not.
  14. 325w
    325w
    Drake 30 years ago.
  15. tubman
    tubman
    They retooled so they could make a gasket that didn't fit? Or maybe they are reselling Vintique?
  16. cmusser
    cmusser
    You are right Tubman. I called Bob Drake and verified they make their own and are not as thick. I'm going to order one of theirs as soon as I put a bigger order together. Thank you!!
