Does anyone know what parts (number and supplier), are correct replacements for a 32 5-window rear "roll-up" window? I purchased a "Vintique A-48105-A" regulator and a "United Pacific B20117" channel (goes between regulator arm and gl***), but the round knob (or bushing) on the end of the regulator arm won't fit the slot in the channel. Note; the A-48105-A regulator is for a 32-34 truck right-hand door, but also states it can be used for the rear "roll-up" window in a 32 coupe. It is a 3-hole design. I have found a 4-hole that CW Moss sells (# A-48105-B), which states it's for the rear window application. Just trying to figure this out. Any help is appreciated. Thank you!
This might help https://www.fordbarn.com/forum/search.php?searchid=58023665 The first one has a bunch of posts and talks about the various suppliers and parts. I didn't see an original parts listing and cross reference.
Not sure this will help.I bought a tray that catches water under the window and the brace that the regulator mounts to from speedway.united pacific parts they fit better than any aftermarket ford parts I had ever bought all the holes lined up perfect.my regulator was the factory ford piece.had a couple photos hope they help
Question for Tim regarding pictures sent. Is your regulator a 3 or 4-bolt mount? I can only see two mounting screws being used in the picture. Thank you to both of you for your replies to this. Very helpful!
United Pacific B20218 - Window Regulator - Back Window Regulator Plate, for 1932 Ford 5-Window Coupe . looked up the part above it looks like it only has 2 holes. then found this image
