question on choosing the right carb.
Discussion in 'The Hokey Ass Message Board' started by fluiddrive1949, Apr 9, 2012.
  1. fluiddrive1949
    fluiddrive1949
    from Austin TX
    I have a 1954 cadillac hearse that needs a new carb I was going to re build the original but found out just now ( the car is 1000 miles away) that it has some cheap replacement that needs to go. Can anyone tell me what a good size would be for a stock 331 cadillac in a 54 cadillac? any help would be great. Thank you.
  2. fluiddrive1949
    fluiddrive1949
    from Austin TX
    Im coming up with 500cfm. sound right?
  3. carbking
    carbking
    Just remember that unless you change intake manifolds, the carb that fits would have the original 4 barrel 3 3/4 x 3 7/8 bolt pattern.
    I would highly suggest looking around for an original and rebuilding it.
    Jon.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    +1 for carbking. It ain't a hot rod and will be much more pleasant to drive/use with the correct carb. For anything modern you will need a adapter plate and then need to get the trans TP linkage sorted out. Old Hydros are not pleasant to drive with miss adjusted TP linkage.
  5. fluiddrive1949
    fluiddrive1949
    from Austin TX
    looks like Ill be taking a trip to the junkyard. Thanks for the info
