Question On HEMI & SBC
Discussion in 'The Hokey Ass Message Board' started by Wild Thang, May 24, 2007.
  1. Wild Thang
    Wild Thang
    The qustion is that use can use a sbc water pump on a Chrysler HEMI 331-392 now is this true? This would help me out alot thanks.
  2. squirrel
  3. swimeasy
    swimeasy
    Learn a stock hemi first, then go to the advanced stuff....PLEASE!
  4. Wild Thang
    Wild Thang
    Wish I could swimeasy but this block has been redone for speed not stock was bought at a speed shop.
  5. bigmike
    bigmike
    I wouldn't call water pump adapters advanced stuff..... since a rebuilt 392 pump is going to cost you over $100 anyway and the availability isn't going to get any better.... now if someone built an adapter to use the B/RB Mopar (4 bolt) water pump in the 392 (5 bolt) casting that would be even better.... IMHO
  6. HemiRambler
    HemiRambler
    Rebuilding a 392 pump can be done on the cheap with a little swap meet luck and access to a lathe. I've rebuilt a few that way - "robbing" the guts out of some other early Mopar pump and then facing off the seal surface on the housing. Here's a link to a page that shows the various pumps that share some commom pieces parts.
    http://www.jalopyjournal.com/forum/showthread.php?t=92512&highlight=hemi+water+pump
    FWIW the SBC pump is too narrow to easily adapt to the 331-392 series motor - but I did see 'em adapted to the "baby" hemis.
    Bigmike - I saw a guy selling a flat adapter on Ebay once to run the 440 style pump on a 392 (4 bolt to 5 bolt adapter). I always wondered how it worked.
  7. bigmike
    bigmike
    Yeah I would think it would only take a plate, the wet deck depth is the same. I was thinking of making one myself when my pump kicked on me, and then I scored a rebuilt one at a swap meet.
  8. bigmike
    bigmike
    Oh yeah, thanks for the link alot of good info.
  9. George
    George
    If you use the long BBC pump, it'll fit with the OEM timing cover (at least it does on the '55 331)
  10. Oldschoolhotrods
    Oldschoolhotrods
    from san diego
    yes you can use bbc waterpumps adapters on most hemis, search the web, they exist and work, i want to say hot heads has em but don't quote been a long time....
  11. man-a-fre
    man-a-fre
    the earlier hemis 51 to early54 331 i believe you can still get the aluminum timing cover with the adapters on it for a smallblock chevy pump,but wont work on 55 up call bob and see availability .
  12. I'm using a sbc pump on mine. The top bolt holes line up. Made my own adapters and didn't have to modify the front cover.
  13. HemiRambler
    HemiRambler
    Kerry, can you post a pic??? I didn't think those would fit!!! (Didn't look feasible when I looked at it - but that was so long ago
  14. Here's an old pic before the blower. The water pump is a B&M. I used a stud on the top hole into the block. The bottom has an allen head cap screw countersunk into the adapter attached to the block and has a stud in the adapter for the pump.
  15. Wild Thang
    Wild Thang
    Thanks for all the help and leads checked out Hotheads and found the things I need.
  16. 64 DODGE 440
    64 DODGE 440
    from so cal
    Good looking set up, simple and it works. Sometimes all it takes is a little modification to put the right parts together and solve the problem and make maintenance and parts availability a whole bunch easier.
  17. HemiRambler
    HemiRambler
    Kerry, Thanks for posting that - I learned something today!!! Kinda neater having at least one bolt per side being a "thru" bolt. I really like it.
  18. Oldschoolhotrods
    Oldschoolhotrods
    from san diego
    glad that helped, haven't used hotheads in years since i was fiddling with a redram
    that sbc waterpump set-up is very cool and good to know
