Technical Question on Making an ignition Key
Discussion in 'The Hokey Ass Message Board' started by Petejoe, May 11, 2023.
  1. Petejoe
    Petejoe
    from Zoar, Ohio
    I have no idea what happened but I’ve lost the keys to my 37 Ford.
    Is it possible to have a key made for my ignition lock cylinder mounted on the steering column??
  2. jaracer
    jaracer
    A really good locksmith can make one on the spot if he has the correct key blank. You need to find one that does that for a living.
    Petejoe likes this.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    thanks. Now to find a key blank and a really good locksmith close to Ohio.
    Are they called a Hurd Key??
  4. ClayMart
    ClayMart
    If you're calling around to find a locksmith, ask if they have someone who can "impression" a new key. They'll need to have the lock ***embly or the vehicle itself at hand to do the work, unless you don't mind paying extra for a "house call".
    jaracer and Petejoe like this.
  5. Jim Recupero
    Jim Recupero
    Most bigger locksmiths company will know what blank you need and like ClaMart said you will have to take the steering column or the whole car to them or pay for a house call Jim
    chryslerfan55 and Petejoe like this.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    Thank you. At least it’s a start. I found a source for key blanks. Dennis Carpenter.
    I may just remove the whole unit off the steering column. Unless AAA wants to tow it to the locksmith. :)
  7. patterg2003
    patterg2003
    chryslerfan55, alanp561 and Petejoe like this.
  8. gene-koning
    gene-koning
    If the ignition switch on your truck is on the column, its not original. Ignition switches on the column didn't appear until around 1971.
    So the problem you have now is you really have no idea even what brand of car or truck the column in your truck came from, or what year it may be.
    Take your column to a locksmith. The key blank will need to match the brand of the column and the year of the switch.
  9. gimpyshotrods
    gimpyshotrods
  10. big duece
    big duece
    from kansas
    20230512_003511.jpg If the lock cylinder can be removed, there should be a code on the side to get new keys cut. I have used this guy several times making keys for '32 lock cylinders.
  11. big duece
    big duece
    from kansas
    clem likes this.
  12. If you or someone has a collection of old keys, sometimes you can get a key which will "jiggle and twist" and open the lock, so it can be taken out to have a new key made.
    Beanscoot and ClayMart like this.
  13. Budget36
    Budget36
    Years back the was a fella on the FordBarn that could cut a key with just the lock number. He’d bought the cutter and a bunch of blanks. He also had the key code chart.
    If he’s still around won’t need a house call.
    Petejoe likes this.
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    Gene, this is on my 37 coupe. Yes original. Not on my 34 truck.
    Thanks.
    I found three big companies carrying that repo but none of them are in stock. I’d imagine there’s only one manufacture with some kind of issue. Cheap price too.
    I’m going to try to have a key made. Looks like the fastest turnover.
  15. rusty1
    rusty1
    ...soon as you get a new key made, you'll find your orignals so you';; have a spare set.
  16. J. A. Miller
    J. A. Miller
    from Central NY
    @Petejoe most lock shops should have an Ilco 1125-S key blank. That would be the same as the Hurd keys.
    Petejoe likes this.
  17. 31Apickup
    31Apickup
    I bought key blanks from Bob Drake, and took the 1940 lock mechanism to a local locksmith and they cut the key for it.
    Petejoe likes this.
  18. patsurf
    patsurf
    i did laugh when i read the further up comment--maybe henry should have made 'em tilt as well!!
    AVater and nosford like this.
  19. Don't you guys have a Locksmith in your areas?! Rapid City is a pretty small area still but we have more than one including mobile.
    Petejoe likes this.
  20. You can't remove the column tube from the steering box if it is in the Locked position. There's a dowel that engages in the steering shaft lock collar to prevent that.
    Petejoe and Tman like this.
  21. Petejoe
    Petejoe
    from Zoar, Ohio
    We’ll that’s just wonderful.
    Thanks for the heads up. Hopefully I’ll get a key made so I don’t have to destroy the whole ***y.
    And yes, I’m sure my original will show up as soon as I get one made. :)
    AVater likes this.
  22. RICH B
    RICH B
    Think it would be pretty easy to drill and pull the retainer pin, pull the lock cylinder, either order a key by the code or take it to a locksmith, and reinstall the cyl when you have a key. I usually tap the pin hole and use a set screw to retain the cylinder.
    Once you have the cylinder out, you can use a screwdriver to unlock the column and ign switch and use your car in the meantime.
    AVater, Petejoe and big duece like this.
