1952-59 Ford Question Speedometer 1956 Mercury Monterey
Discussion in 'Off Topic Hot Rods & Customs' started by Sgt. John, Nov 20, 2024.
  1. Sgt. John
    Sgt. John
    from Virginia
    I have a question..I have a 56 Mercury Monterey and I installed a 1978 Ford C6 transmission and I need to get speedometer cable..Where does a person get one from????
  2. Paul2748
    Paul2748
    First, find out the length you need. Then go to ebay and look up Mustang speedo cables. Usually they note the length in the ad. You will need a cable that has the end that the merc speedo has (which was used for many years) and the trans end needs to have the clip on gear. Be sure to get the clip . You will need the gear that does into the trans. They come in a number of different tooth counts so you will have to make a guess on which one you need. If you find that the speedo is off (high or low) you can get a gear that has more or less teeth depending on which way the speedo is off. Sometimes the clip will come with the gear, otherwise you will have to get it separately
    Some of the later mustangs used a different end at the speedo so be careful when you buy.
    Also, look at other Ford products for a cable. The ends are pretty much universal through out the Ford line so yiu may be able to see different length.
    If you cannot find the right length, then custom ones are available.
    Adriatic Machine likes this.
  3. 51504bat
    51504bat
    SS327, Dick Stevens and jimmy six like this.
  4. evintho
    evintho
    Check the C6 cable's length and end that goes into your speedo. I have a '93 Mustang AOD along with it's accompanying speedo cable. It's 3" or 4" longer than my '54 Ford cable so I just looped and secured it under the car. The speedo end of the cable is exactly the same as the mechanism inside my '54 speedo. The cable slipped right into and onto the '54 speedo. The only mod I made was to add a 3/8" F.I. clamp to the cable end for some extra insurance. The speedo works great!
  5. Sgt. John
    Sgt. John
    from Virginia
    Hello..I bought a cable from Speedometer Services and it work great
    51504bat and down-the-road like this.
  6. Sgt. John
    Sgt. John
    from Virginia
    Good evening to everyone. Got around to finally install the new speedometer cable; Original 56 Mercury to the C6 transmission and works flawless 100% accurate to my GPS
    miker98038 and pprather like this.
  7. Sgt. John
    Sgt. John
    from Virginia
  8. pprather
    pprather
    Wow! It took less than a year to install the speedo cable.
    Nice Merc!
  9. miker98038
    miker98038
    Now that your phone has a gps, some of us aren’t are motivated as we used to be. But thanks for posting it .
  10. Sgt. John
    Sgt. John
    from Virginia
    HAHAHAHAHAHA.Been busy.
    pprather likes this.
