Question??? steering u-joints...
Discussion in 'The Hokey Ass Message Board' started by DIRTYT, Feb 16, 2006.
  1. DIRTYT
    DIRTYT
    from Warren,MI
    How should they be synchroed (sp) or does it matter? i only have two joints in my set up and just want to make sure i put them on the right way.
  2. squirrel
    they should be set up so the joints on the middle shaft are in line...probably not a big deal, but why not do it right?
  3. DIRTYT
    DIRTYT
    from Warren,MI
    thanks it seemed to work smoothest with it like that any way. now i can go back to the garage and finish this damn project!
  4. stickylifter
    stickylifter
    from Detroit
    You gotta phase them just like a drive shaft.
    I have 3 and so I'm screwed.
  5. Slag Kustom
    Slag Kustom
    all the late model cars with 2 joints on the shaft have them set 90 degrees apart.
  6. squirrel
    I just looked at one I have from an early 80s fwd car...it's about 60 degrees out of line.
    Ok, I give up!
  7. I go along with Squirrel's original post.
    Besides, how do we know some ace meckanik didn't put the steering column back together incorrectly?
  8. I second that, as long as it's smooth that's all that matters.
  9. squirrel
    The one I looked at was not modified...it's a welded ***embly.
  10. rattlecanrods
    rattlecanrods
    It all depends on your shaft angles are set... The bigger the angle change the higher the velocity variation. You use joint phasing to cancel out the velocity variations of multiple joints. When using 3 or more joints you have to compromise.
    So whats yer angles?
  11. Slag Kustom
    Slag Kustom
    looking at the coluom i have sitting here it is keyed to be 90 degrees apart on the center shaft.
  12. 38racing
    38racing
    I not cleare why you say this. Would you not phase joint 2 with joint 1 and then joint 3 with 2?
  13. Hackerbilt
    Hackerbilt
    Just pondering something here...
    Phasing the joints is done in driveshafts to allow for the constant speed variation of the shaft due to the mounting angles and HIGH ROTATIONAL speed of the shaft.
    A harmonic (or worse!) vibration is set up "in use" but the shaft doesn't vibrate when it isn't turning...soooo....
    If your getting a harmonic vibration from turning your steering wheel so fast you got problems other than the joints!!!
    In a steering system I can't see phasing being a huge issue...other than just in looks.
    I'd set them IN phase myself just because...
    but I can't see it hurting either way...just set the angles of the joints within the recommended limits to prevent actual binding.
  14. stickylifter
    stickylifter
    from Detroit
    You will notice a difference as you get farther away from being "in phase." Speed has nothing to do with it. It's a matter of leverage and the nature of the U joint. I have 3 joints in my steering. 2 are in phase, the other one I adjusted as best I could but there is some noticeable resistance at 12oclock and 6 oclock because of the "phase."
  15. muffman58
    muffman58
    I beg to differ on this. You take a two piece driveshaft and put it back together out of phase and go drive it about 70mph and tell me what happened! You think Harleys vibrate!
  16. Hackerbilt
    Hackerbilt
    No no...he's talking about steering joints for sure...no question on the driveshaft importance of being in proper phase!
    So you CAN feel a little...pop over center kinda feeling without having them in phase?
    NOT just the joints binding from excess angle?
    Like I said, I've always had them in phase just for the cleaner look, but I didn't think it would matter at all in such a slow turning setup as a column shaft.
    I gotta check out some factory setups I have kicking around...never did really check for phasing on them. This is interesting...
    (And I'm NOT saying your wrong either! I've just never tried it myself but really didn't see an issue...its all a learning experience! LoL)
  17. stickylifter
    stickylifter
    from Detroit
    Uh, dude... We're talking about steering here...
  18. BigEd
    BigEd
  19. rattlecanrods
    rattlecanrods
    Excatly Mark.... We are talking about 2 different systems here.
    The velocity variation in a steering system results in a different in turning speeds across a u-joint. The higher the angle change the greater the speed change. The overall result of an improperly phased steering system is a fluctuation in torque-to-turn of the steering wheel as it is turned or lumpy steering wheel feel. The worst of this an uncontrollable steering system where you will experience certain points in the turn of the steering wheel which causes the wheels to turn quicker than expected. In a properly phased system you should feel the same resistance at the wheel throughout the turn lock-to-lock.
    BTW: Steering system engineering is part of my job.
