Question: Wide 5 wheel width?
Discussion in 'The Hokey Ass Message Board' started by Bull, Sep 23, 2010.
  1. Bull
    Bull
    As the ***le states, what is the width on wide 5 wheels?
  2. elmitcheristo
    elmitcheristo
    I believe mine are four inches wide. 36 - 39 Ford.
    -Mitch
  3. thunderbirdesq
    thunderbirdesq
    There are a few out there that are 3.5"...
  4. i think the 3.5" are for a V8 60
  5. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    3.5 are in fact V8-60's. The rest are 4" wide....well at least for 36-39 Ford Wheels.
  6. Dad's 1932
    Dad's 1932
    from Santa Rosa
    I have a set that are 5" wide . I was told they came off of 3/4 ton trucks ?? They are a nice looking wheel . They lean more towards a 40 style wheel in looks but still the wide 5 pattern .
  7. I think the Lincolns were 5 inch but I am not a Lincoln expert.
    Charlie Stephens
  8. gimpyshotrods
    gimpyshotrods
    All the above mentioned were the widths available from the factory. Anything wider would be an aftermarket wheel.
  9. Bruce Lancaster
    Bruce Lancaster
    As far as I can tell from the catalogs, wide 5 Lincolns used the normal Ford 85 wheels.
    There are a few wider Ford one from 3/4--1ton truck applications, which ran right up to 1947, but they would be pretty scarce...don't think those trucks were EVER common.
  10. just went to an old junk yard that I haven't been at in years, found a stash of old wheels that I'd like to go thru when I have more time
  11. Bull
    Bull
    These are the wheels I have. I believe them to be 4" wide. Would they be wide enough for 8.90-16 Firestone Dirt Tracker Grooved Rears?
  12. gimpyshotrods
    gimpyshotrods
    Those look closer to 7.50 x 16's. That is what I run on my A, on 16 x 4's. I think that 8.90's would be too wide for a 4" wheel. The 7.50's are pushing it.
  13. AJofHollywood
    AJofHollywood
    I learned a lot about wide-5s in the last year searching for a pair of 3/4 ton wheels. They came in 3.5", 4" and 5" (for the truck again). Lincoln was in fact the same as the Fords, only the caps were different. The 4" are super easy to find, anything else ussually takes a lot of effort and extra money.
    I'm using the 8.90 'stones on a pair of 16x5 I found --even though Coker said the minimum width should be 6" when I asked. I haven't installed them yet.
  14. Bull
    Bull
    Yes, they are 7.50-16. That is my roadster in the pic.
  15. Bull
    Bull
    Yeah, I believe I read in the Coker catalog that the recommended wheel width for the 8.90-16 grooved rears is 6-8". I was just wondering if anyone had experience putting them on anything narrower.
  16. gimpyshotrods
    gimpyshotrods
    Sorry, still on just one cup of coffee.
    VERY nice ride. My next A will be of of a similar theme.
    The 3/4-ton wheels, which are 16 x 5, look a little different. Here is a picture of them on Hamber NealinCA's pickup, shown with Lincoln caps.
  17. AJofHollywood
    AJofHollywood
    Ask me again how well the 8.90s fit 5" wheels in two weeks, I'll know by then.
  18. elmitcheristo
    elmitcheristo
    When I ordered tires for mine from Coker, they told me that the widest they would recommend for a 4" wide 16" wheel is a 700. Even with the 700's, they're plenty big enough. But, as previously mentioned, I've seen plenty of 750's on 4" wide wheels.
    -Mitch
  19. Bull
    Bull
    If they made the dirt track grooved rears in narrower widths in 16", I'd go with them. Since they don't my options are limited.
  20. AJofHollywood
    AJofHollywood
    I only bought the track tires because I got a smoke'n deal, otherwise I would have bought something else. I really cannot afford $300+ a tire, or whatever it is again. For a lot of people, it's a must have item, and I understand that. Tires & wheels 'make' a car.
  21. gimpyshotrods
    gimpyshotrods
    I do love the look of the grooved dirt-track tires, but I think that they are going to be a bit too wide for the 16 x 4.
    Have you looked into widening, or re-shelling?
  22. jason12872
    jason12872
  23. Bull
    Bull
    Thanks for the tech.
  24. jtille
    jtille
    I put 750s out back 16x4 wide 5
  25. Shaggy
    Shaggy
    from Sultan, WA
    by 41 they had gone to anouther bolt pattern that is not the same bolt circle, i think it is like 6 1/2" or something like that, or atleast that is what was on a '41 rear i used for quickchange parts, Now I know for a fact some of the timkin rears (38-52 3/4 and 1 tons) used a wide 5 drum, and i know there are wheels that are wider and have a few slots instead of the ford wagon wheel look, But i dont know of the applications. Im in the market for 2 of the 3/4 ton drums and 5 of the wider wheels if anyone knows of some
    Also it should be remembered that many of the large trucks had split rims and big diameter wheels too, I dunno if it was that early tho. So if anyone knows anything about this stuff i'd love to hear
