Event Coverage questions about Bonneville 2010.
Discussion in 'The Hokey Ass Message Board' started by 51Hg, Jul 12, 2010.
  1. 51Hg
    51Hg
    This will be my second year at Bonneville. I was wondering about somethings?
    What type of scanner is a good scanner to use to listen to the times over the vhf? we listened to the radio in the car but they lagged behind real bad. Is there something i can get at radio shack?
    Second: last year there was a thread here and in Hot Rod Magazine that there was a sight of a aircraft crash where someone found the pilot's dog tags. where is that sight and can anyone tell me how to get there?
    third: what else is there to do while out there? I saw here that they gave a tour of the old hangar one day? i missed that last year. what other things are going on that I might not want to miss?
  2. 51Hg
    51Hg
  3. Mr48chev
    They used to do it on CB radio. Not sure if they still do. That or low powered FM radio.
  4. rockstar96
    rockstar96
    When we competed in 2007 everything was done over th CB radio so you want a good handheld if you are walking around or one in the car if you are driving around.
    David
  5. 23reotim
    23reotim
    from arizona
  6. mike hamel
    mike hamel
    I recommend going to the WWII era hanger! It was so interesting and is quite a place to take a photo of your car. We all went there last year around sun set and got some great pictures. We use the radio in the truck to listen to the broadcast on the track.
  7. Yes, CB is the main communication used between tower and racers. It switches between channel 1 and 10, usually, depending on interference.
  8. 51Hg
    51Hg
    Any more suggestions
  9. speedtool
    speedtool
    Don't forget the low power broadcast from the salt on AM.
  10. Any info you need can be found on landracing.com Just do the search for the info you need! C U on the Salt.
