Questions about brakes for 1955 Buick
Discussion in 'The Hokey Ass Message Board' started by tcarrasco84, Jan 1, 2013.
  1. tcarrasco84
    tcarrasco84
    Hello all, iam curious if anyone has ever out in 60s style master cyl/booster firewall mounted in a 55 or 56 Buick. My Buick special is drum/drum and a original power brake car. The treadle vac was gone form the car and don't plan on going that route. I'm not looking to go complete resto on the car. Will something like work? http://www.speedwaymotors.com/8-Inch-Dual-Brake-Booster,9557.html
    What have you used? Let's talk. Thanks everyone, and happy new year!
  2. F&J
    F&J
    If it were me, I would call ECI brake in Ct. I had a 56 Olds here with the stock under floor master, and I am sure ECI would have something that would fit mine, and would have the correct master for drums.
  3. tcarrasco84
    tcarrasco84
    Thanks man, I'll see what's up
  4. you are going to have to remove the air duct housing, make a plate to cover the hole, and then hang some swing pedals. i used a set from speedway, but if i did it again i would get a set out of a '70's-'80's era gm. tying the firewall to the dash, where the column mounts to the dash will stop any firewall flex.
  5. tcarrasco84
    tcarrasco84
    Thanks, like I said any advice helps. It's all a new process for me,but I'll get it done.
  6. tcarrasco84
    tcarrasco84
    Could you direct me to a link of what type of pedal your talking about
  7. metalix_421
    metalix_421
    This may give you a little piece of mind. My 56 olds with the Speedway kit, stock rebuilt drum brakes. sorry for the crap picture
  8. tcarrasco84
    tcarrasco84
    See I love that look, did you get the booster from speedway too? The air duct covers are already gone so that will be easy,and I know what you mean about the supporting of the firewall.as far as I've heard the flex could be bad if not done.
  9. metalix_421
    metalix_421
    the way I did mine is
    speedway kit bb/mc and pedel i think it was $229
    3/8 steel plate takes place of the cover
    I used all bolt holes that were in the firwall.
    It seemed to be pretty solid just like that
    there is a bracket that came ith the kit that I bolted to the bottom of my dash.
    I did that just for a little extra strength.
  10. tcarrasco84
    tcarrasco84
    Damn that sounds good, you don't have links to actually what you got on there? I'm finding a lot on speedway. Someone had mentioned having a 8 inch booster
  11. metalix_421
    metalix_421
  12. blucar
    blucar
    I used the peddle assembly out of a '79 Cad Seville and a tilt column from a '78 Chevy van for the conversion on my '50 Olds 88... Had to do a lot of modifications to the firewall, removing air ducts and creating a flat area for the peddle assembly/booster to mount to...
    I prefer to use factory parts for these kind of conversions, that way any parts, neutral safety switch, turn signal switch, booster, peddle pads, etc., are all stock GM parts..
  13. metalix_421
    metalix_421
    It took me an afternoon to mount it with only making 2 cuts to fit it through the vent in the fire wall.
    I like GM parts too thats why I used my GM drums and and suspension:cool: :eek:
  14. tcarrasco84
    tcarrasco84
    Been a lot of help thanks man, I appreciate it.
  15. metalix_421
    metalix_421
    no problem, PM me if you have any other questions, also the bb/ mc are gm style
  16. tcarrasco84
    tcarrasco84
    Yea everything with the Buick is gm, obviously.haha the whole brakes thing are new to me so it's good to talk to someone who will actually talk to me about it. I think I need to go with a 8 inch booster to provide enough braking power to stop the car.
  17. drptop70ss
    drptop70ss
    from NY
    If you plate off the duct work on the firewall does that disable the complete heater system? I assume you would swap to a vintage air or smaller under dash unit? I have a 55 buick that I plan on updating the braking system, just got the car so I have not dug into it yet.
  18. you will loose the fresh air vent on the drivers side.
  19. drptop70ss
    drptop70ss
    from NY
    thanks, that will not be a big deal.
  20. tcarrasco84
    tcarrasco84
    I'm still working on this as money has been an issue and with the holidays done were getting back on track.long story short making a parts list of what I'm needing here but still making progress
