Questions about plexi glass windshields?
Discussion in 'The Hokey Ass Message Board' started by fatty mcguire, May 20, 2007.
  1. fatty mcguire
    fatty mcguire
    Im prolly buying a chopped 54 merc and right now it has plexi gl*** windshield in it and I plan on driving the car daily, Im wondering If I can use wipers on it with out scratching the **** out of it. IF not that could I at least rain x on it? or will it haze it up.
    I plan on having a gl*** one cut for it, but might take time finding one and having it cut to fit, I know the guy and he had one cut to fit but when he was putting it in I think he dropped it or something
    thanks
  2. hotrod1940
    hotrod1940
    The answers are not the ones you want to hear about this situation. Plexigl*** will weather and scratch. It is undoubtably illegal because of the shattering qualities. All cars are required by law to have shatteerproof gl***. This is a no win situation and that's a fact.
  3. Da' Bomb
    Da' Bomb
    Plexiglas scratches pretty easily...I have on in my roadster and it's marred up from just using a clean, soft towel.
    Pat
  4. RichFox
    RichFox
    Maybe you have a Lexan windshield. They don't shatter and are used in aircraft. Lexan with MarGard is a little harder to scratch
  5. fatty mcguire
    fatty mcguire
    you know what, it might be lexan, dont remember, but again same question's then about it, can i use wipers on, or at least can I use rain x
    thanks for the reply' s so far, and like i said I would like to get a real windshield in there
  6. buflochp
    buflochp
    from Minnesota
    The only chopped cars I have ever seen with Plexiglas windshields are the ones that screwed the top so a safety gl*** windshield will never fit without cracking from stress. You may be buying something you can never make legal. If its got plexiglas it better be cheap.
    buflochp
  7. godredger
    godredger
    I also purchased a car with a plexigl*** windsheild. I have just replaced it with safety gl***. The plexi was terrible! I couldn't even clean the bugs off, because it would leave scrathes. Forget about using a wiper.
    godredger
  8. merc-o-madness
    merc-o-madness
    Aha What A ****ter!!!
  9. gahi
    gahi
    from Moab, UT
    Lexan scratches just as easy.
  10. Oggie
    Oggie
    from Nor Cal
    What ever it is do not use a gl*** cleaner on it, it will haze real quick. Not sure if Rain-X will do that, but the products with ammonia will cause a lot of damage and will eventually cause crazing.
    Oggie
  11. 54 merc is a simple windshield to cut. make sure that it was welded proper. I have seen some simple windshield keep stress cracking from body flexing.
  12. kool1
    kool1
    I have a 60 olds with lexan windshield that will be replaced before I take out again. Its those lite scratchs that reflect light thats the killer. I had to wear sungl***es even at night to reduce the glade it had.
    Using wipers will really scratch it up as they will have some dust and sand on them from the wind when its dry and once you go to use them when rain starts you'll just gouge the windshield with it.
    I would replace with gl*** asap
  13. fatty mcguire
    fatty mcguire
    Well I found out its lexan in there for know, can I use rain X on it does anybody know? I was just gonna buy a brand new windshield for it but he told me dont waste my money because there alot weaker than the nos ones are so I gotta look for an orginal one, but for the mean time Im wondering if I can use rain x?
  14. Mudslinger
    Mudslinger
    It sounds like he has already tried that?
    I would look that car over really close. Like said before it sound slike it may be screwed up causing windshields to crack.
  15. fab32
    fab32
    How about if you tell him you'll buy the car if he puts a real windshield in it. If that queers the deal you just saved your self a REAL headache. No gl***, no deal.
    Frank
  16. custom61
    custom61
    i have plexigl*** on my road race car and i have used rain x on it a number of times without any problems... but it is a race car and not a daily driver so i hope that helps out a little!!!!
  17. pan-dragger
    pan-dragger
    probably can't put a windshield in it. i'd be leary of that one.
  18. fatty mcguire
    fatty mcguire
    I know the guy, he does pretty good work, he did a 56 merc and it looked really good, I really do believe that gl*** shield would be fine, he said if I find a nos windshield hed have it cut and put in for me
  19. 1320stang
    1320stang
    from Edmond, OK
    Percy's Speedgl*** makes Lexan that has a coating on it for drag cars. You can take steel wool to it and not scratch it. I still recommend making it legal with safety gl*** though.
  20. Mudslinger
    Mudslinger
    The whole thing of only using a NOS windshield is what worries me.
    I have never heard that unless someone was trying to save a few bucks but not because its thicker, that sounds like stress problems to me and that he has tried a new one and went with lexan.
  21. MarkX
    MarkX
    from ...TX
    I used plexi in a couple cars I chopped cuz at the time I couldnt get new gl*** and/or didnt know how to cut it and the guy that said he could told me he'd go thru 3-4 new windshields before he could cut one without cracking it and i believed it was almost impossible to have a affordable chopped gl*** windshield. so I rolled with plexi....... till new windshields have become more avail. under $200 and I could easily cut one myself.
  22. pussykat66
    pussykat66
    I use LEXAN with MARGARD in my race car....there's a cleaner that I got with it just for the LEXAN....it works like rain-x and I dont have a problem with scratches....
  23. CB_Chief
    CB_Chief
    from Oklahoma
    My experience has been that original windshields are more brittle than new ones. I have damaged more than old one in the last 35 years trying to put it back in the car.
  24. I called them and they sent me a sample. It really works, and I rubbed harder than a soft rubber windsheild wiper. 1-888-737-2970
  25. alleyoop
    alleyoop
    I put lemon furniture polish on our loging skidders winschilds and it keep the dust off and takes the scraches out hard to bleave but it works.AS for plx. windschild i would change it out fast ,if it is too thin it will bend and come back in you face not good any you put it. alley
