Questions about wiring
Discussion in 'The Hokey Ass Message Board' started by oldfart, Dec 3, 2013.
  1. YUP! A wonderfully honest HAMB member from Oklahoma.Oh yeah,I paid $25,000 for it plus shipping.
  2. KJSR
    KJSR
    from Utah
    Your starting to repeat yourself......
  3. 1971BB427
    1971BB427
    from Oregon
    Well I guess I'd give it some time to settle in. Whenever you first look at a new purchase you're bound to be overly critical of the car, and your purchase. Don't beat yourself up, just take some time to give it a good look, and then address each item as you find it. I wouldn't totally rewire the car unless you find things aree much worse than a few connections.
    I'm not sure what the inline fuse at the firewall is hooked to? If it's the main feed to the fuse block, then it should have had a fusible link down at the starter, and someone may have put in a new wire and the fuse to protect the main feed. If so, then I'd get a new fusible link and replace the wire from the starter up to that point to eliminate the fuse.
  4. jeffd1988
    jeffd1988
    You lean something new everyday. As mentioned earlyer. But hey its a older car it better wiring than some dry rot or something crazy like that. But its a hobby these (old cars) just dont beat yourself down to much. Just lesson are learned everyday. And thank God you find this issue and not have a fire hazard on the freway or something. Just simply fix the issue and enjoy the vehicle.
  5. rfraze
    rfraze
    I think it's: You paid for what you got.
    Check battery voltage. If it is below 12.3 or so, charge battery.
    Get yourself an open barrel crimper and if that connector fits the alternator, crimp it properly, bend the tab that holds it in the insulator back up, push it back in the insulator, and reinstall on the alternator. Fire it up and take a voltage reading at the connector to make sure the alternator is charging.
    Check battery voltage tomorrow. If it is below 12.3v or so, you have a drain or bad battery. Auto stores will load check batteries for free. If the battery is good and you need to inspect under dash, do yourself a favor, and remove the seat (as posted above).
    Check the inline fuse and figure out what it powers (bet it is a relay near front somewhere) for future reference. If you decide to keep that in line fuse, they have covered and waterproof versions.
  6. chaos10meter
    chaos10meter
    from PA.
    By working on it you will get to know it better
  7. Leakie
    Leakie
    Why do people dig up 2-3 year old threads to respond to? I'm confused!
    Hnstray likes this.
  8. bobss396
    bobss396
    Gotta love a good zombie thread resurrection!
  9. wbrw32
    wbrw32
    In most cases, Its a newby that don't read very well!!!! or even understand how the HAMB works
  10. This thing's so old it don't have the unsubscrib feature. Smells like Moth Balls.
    The Wizzard
  11. Anybody get the moth's opinion?
  12. 54vicky
    54vicky
    I am sure some like to watch their post count climb.
  13. Gman0046
    Gman0046
    I wonder if he still owns the 61?
    Gary
