Hot Rods Questions for search ninjas
Discussion in 'The Hokey Ass Message Board' started by thirtytwo, Oct 23, 2016.
  1. thirtytwo
    thirtytwo
    i really hate the search function , what are the tricks?
    Been looking for a thread from a couple years ago where a guy from France built a 3w from 2 34 sedan quarters I have come up with zero also looking for other homemade coupe from sedan threads
    ~thanks
  2. cretin
    cretin
    thirtytwo and Stogy like this.
  3. Stogy
    Stogy
    thirtytwo likes this.
  4. thirtytwo
    thirtytwo
    That's it !.. I tried every combination I could think of .. Almost hat his user name right too ... Couldn't make Google work either ... Thanks guys any other coupe conversion threads are welcome also
    kidcampbell71 likes this.
  5. Truck64
    Truck64
    from Ioway
    Not Ninja status, but the search function here (or the APP anyway) is _***les_ only. There may be some exclusion character jiggery-pokery to be used too, but I dunno what they are.
    If you want to drill down deeper and restrict the search to a specific website try using the Google search like this; Say you want everything for example on distributor curving, type in the search bar:
    distributor curving site://www.jalopyjournal.com
    Some websites are really only searchable this way
  6. cretin
    cretin
    Guys, I'm talking about using the google search tab on here.
    I only used info I got from this thread to find it. I typed "France 3w 34 sedan". I got only one result, this thread. But up at the top of the page there are 2 tabs. One is "site results" which only gave me this thread. The other is "google results" I clicked on that an the thread was one of the top results.
    kidcampbell71, thirtytwo and Stogy like this.
  7. Truck64
    Truck64
    from Ioway
    Well, whatever works for you. Many sites are really only searchable effectively by using the site:// method externally. When I want to "read up" on a subject, it works. JalopyJournal has some of the best mechanics too. In fact I'm quite certain this was how I found the site, it kept popping up in searches.
    thirtytwo, clunker and Stogy like this.
  8. manyolcars
    manyolcars
    This website has the most and best information available. An Index would make it possible to find it all.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Learning all the basics and it works great. HRP
    This is Ryan's tutorial
    First thing you should know is that the key to searching is using the "search icon" found here:
    When you click the search icon, you will see a search drop down appear. It will look something like this:
    So what does each of the fields and ****ons do? Simple:
    1. This is the field where you enter your search term. You can enter something simple like:
    This will return all threads and posts that contain both the words "ford" and "roadster." Or, you can enter your search in quotes like this:
    This will return all threads and posts that contain the phrase "Ford Roadster" - both words together as typed.
    2. Click this checkbox if you only want to search the ***les of posts.
    3. In this field, you can limit your search to a specific user only. Just type that user's username in this field.
    4. If you would like to limit your search to a certain date or range, just use this text field.
    ****5. This is a very important checkbox and one people should pay more attention to. Depending on where you are on the H.A.M.B., the function of this checkbox changes. For example, if you are in the "traditional hot rod" forum and you only want to search that forum (and not the entire H.A.M.B.), you would sure to check this box as it limits the search to the forum you are currently viewing.
    6. This is another important checkbox. If you want to view ALL threads and posts that are returned with your search term included, do not check this box.
    However, if you only want to see the threads that included your search term you would want this box checked.
    Try it out - it will make sense once you do.
    7. Clicking this ****on will take you to the advanced search page which gives you additional power to search things like:
    - Threads & Posts
    - Profile Posts
    - Media
    8. Click this little arrow for common searches like:
    - Recent Posts
    - Your Threads
    - Your Posts
    - Your Profile Posts
  10. thirtytwo likes this.
  11. Just Gary
    Just Gary
    Another search trick is to do a search using commonly misspelled words; e.g. axel, eldebrock, kustom, etc. :confused:
