Technical Questions for the engine builders.
Discussion in 'The Hokey Ass Message Board' started by 2002p51, Dec 29, 2017.
Tags:
  1. 2002p51
    2002p51
    I'm going to build a 289 Ford for an OT project. Still in the parts gathering phase right now but have a couple of questions. How long will ***embly lube remain viable? In other words, if I build the engine now but it's up to a year or so before it's installed in the car and ready to fire, will the ***embly lube still do it's job?
    Also what's the best gasket sealer for things like oil pan, intake, valve covers, etc.? Silicone, RTV, or old school Permatex?
    Thanks in advance.
  2. Torana68
    Torana68
    from Australia
    I like permatex, the only bit Id be worried about is the cam/lifter but 12 months should be ok , is it short block or fully ***embled so you can seal it up?
  3. 2002p51
    2002p51
    It's a short block right now but it may need to wait awhile once it's a complete engine.
  4. boring-hop-yard
    boring-hop-yard
  5. I've had mixed results. Now I just leave everything bagged and boxed up till it's time. If you must build it leave the pushrods out so the Valves stay closed till it's in place. Clean sharp valve faces don't like condensation and Vermin love little tiny spaces. Clean and inspect all your machine work, bag it all up and wait. You won't regret that move.
    The Wizzard
    metlmunchr, 302GMC and oj like this.
  6. Boryca
    Boryca
    from Detroit
    Use this for ***embly lube, and rotate as minimally as possible until you start it up.[​IMG]
    That said, also note that you don't want to add anything to your break-in oil. All that zinc additive stuff actually tends to make the oil worse at doing its job than it was originally. Use a high-mileage oil from Valvoline or Mobil and you'll be fine. I personally like Mobil 1.
    As for gasket sealing, most of us (myself included) use some sort of RTV sealant, but it's not required. It's done because we all want to "guarantee" a seal, and the silicone stuff tends to fill any voids that the gasket won't form into. Really all you need are the proper gaskets and some gasket sealer. I like Indian Head on the intake gaskets, water pump gaskets, and any paper gaskets.
    https://www.permatex.com/products/g...permatex-indian-head-gasket-shellac-compound/
    Cork gaskets can go on dry, but I like to add some copper spray to them https://www.rockymountainatvmc.com/p/941/31927/Permatex-Copper-Spray-A-Gasket-Hi-Temp-Sealant
    You can also use high-tack for paper gaskets (I don't recommend for intake, but it's good for anywhere else) https://www.permatex.com/products/gasketing/gasket-sealants/permatex-high-tack-gasket-sealant/
    Last, but very importantly, use high pressure moly lube on the cam. http://www.nevlock-performance.co.uk/clevite-lube-2.html
    You can get all this **** at NAPA, the links just show you what you're looking for.
    Mike
  7. 2002p51
    2002p51
    That's where I'm at right now, leaving everything boxed up and waiting until the car is ready for it before I ***emble anything. I'm just anxious and want to get it built even though I know it won't be going in the car anytime soon. :)
  8. 2002p51
    2002p51
    So, you don't recommend any of the commercial "break in" oils like those from Joe Gibbs Driven or others?
  9. buffaloracer
    buffaloracer
    from kansas
    I'd follow Pist-n-Broke's advice. At fire up time I like the moly and zinc. Keep in mind that moly will plug the filter if you are using it a full flow set up. While like Mobil 1 it is not something I would use in an engine until it is well broken in.
    My $.02.
    Pete
  10. the 283 in my `36 ford sat for 7 years fully ***embled before i fired it for the first time. Lubriplate #105 ***embly grease on the rods , mains and seals. moly cam grease on the cam and lifters. motor oil on the rings/pistons/cylinder wall. rocker arms were left loose so all valves were closed. all openings and ports were sealed off. then the motor was covered with a plastic bag
    right before the first fire up the valves were set, and cylinder walls oiled. 8500 miles later all is fine
    the 283 in my `30 coupe sat for 2 years with the treatment
    Truck64 likes this.
  11. Joe H
    Joe H
    There are to many opinions about break-in oils, I use them, some don't, it's up to you to decide if the extra cost is worth it. This is pretty recent, test-procedures-prove-race-oils-differences. I use Brad Penn or Comp Cams oils.
    If you decide to build the engine now, use a grease on the bearings, not the oil ***embly lube, and for the camshaft, use the moly grease, not the red or green cam lubes. Don't adjust the valve train or rotate the engine, then seal the ***embly as good as you can in plastic bags. I am building a Pontiac right now that won't see the road for a couple of years. I will break it in on a test stand, then back off the rockers, seal it up tight, and store it in a climate controlled garage. It will store better being broke-in, when it comes time to install it, a quick prime of the oil pump with fresh oil and it will be good to go with no worries about weather or not the grease slid off the lobes or bearings. When getting ready to store, I drain all water while the engine is still hot, the heat of the block will dry up any remaining water so I have no fear of freezing in case of power lose. Don't use tape to seal openings, it won't last and it will leave a nasty mess to clean off later. Don't use plastic plugs either unless the can see them at the openings or you tie flags or strings to them, you sure don't want one migrating into the engine.
    Two or three industrial plastic bags is all thats needed. Pallet wrap, clear plastic wrap would also work good, you can pull it tight and really get a good seal on it, the trick would be getting on the floor or in storage with out tearing the plastic seal.
  12. Boryca
    Boryca
    from Detroit
    No, I don't, except for rare cases. Hit the link below to see why. This individual has run rigorous tests on hundreds of motor oils to see how they perform, and unlike corporations, he's not selling anything. See for yourself and see how your favorite oils stack up.
    https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
    2002p51 likes this.
  13. JOECOOL
    JOECOOL
    I would just wait and ***emble it when I was ready to use it.
    47ragtop likes this.
  14. 2002p51
    2002p51
    Yea, I think that's where I'm at. :)
  15. greybeard360
    greybeard360
    Lube it as normal, bag it up. When you install it.... Prime it and fire it up.
    I have installed many brand new motors that I know sat on the shelf at Ford for a few years. They didn't worry about any special lubes... Just motor oil when ***embled. Primed the ones I could... Those with the oil pump on the end of the crankshaft... Fire them up and watch the gauge.
    Main thing is make sure it is sealed up good and bagged to keep dirt, dust and moisture out. A couple of desiccant bags put inside your plastic bag wouldn't hurt either.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    Boryca likes this.
  16. lostone
    lostone
    from kansas
    I'm one of those that cover parts in either wd40 or I use a mix of Napa engine honey and lubriplate. Heavy trash bags and then I put each head, crank, etc in its own trash bag. Squeeze it tight to the part and twist tie close. I've had parts stored for 2 yrs that way. Pulled them out and just ***embled complete with the honey and lubriplate mix except for the heads.
    I use the mix as an ***embly lube. I have a couple motors with over 125,000 miles and never had a valve cover off.
  17. Torana68
    Torana68
    from Australia
    you dont want any "friction modified" type oils for ring bed in, therefore a break in oil or something without the friction modifier is best (that data from 540Rat doesn't cover ring break in )
    Boryca likes this.
  18. bobss396
    bobss396
    I use Permatex Ultra Slick ***embly lube, it stays on pretty well, really thick stuff. My engine builder recommends starting a fresh build with Valvoline VR1 10w-30. You want the oil to flow instantly and you'll be dumping it after the break-in. I used a break-in additive per the instructions that came with my cam (Lunati).
