Technical Questions on this SW Speedometer
Discussion in 'The Hokey Ass Message Board' started by Duke, Jun 16, 2024.
  1. Duke
    Duke
    IMG_3588.jpeg IMG_3586.jpeg IMG_3587.jpeg Hi,
    Does anyone know what the round door is for on the back? Should I be oiling this speedometer before it goes back in service?
    Thanks
    Just Gary likes this.
  2. Duke
    Duke
  3. Oneball
    Oneball
    This is a complete guess but does the door cover a an adjuster that can be used for calibration? Have you opened it and looked in?
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    @e1956v should be able to help
  5. alchemy
    alchemy
    Probably where the brake was attached originally. When installed in cop cars they were supposed to be stopped at the high speed with a brake in the mechanism. That was proof that the cop was chasing you above the speed limit.
  6. poco
    poco
    from oklahoma
    Alchemy where did you hear that?
  7. e1956v
    e1956v
    Alliance Vendor
    Correct, the side mechanism has a rubber stop that will hold the speed cup and the speedometer needle in place for the officer to show the driver that he was paced and what speed he was clocked at.
    Some were electrically operated by remote switch, others by hand.
    Bob Lowry likes this.
  8. Duke
    Duke
    Thank you,
    Is there anything I should service/lube before I use it as a speedometer? It has a ****on on top that I think was a manual stop as well as a wire going in the back.
  9. e1956v
    e1956v
    Alliance Vendor
  10. e1956v
    e1956v
    Alliance Vendor
    There is an oil wick but its only accessible if you take the speedometer out of the case.
    Hook it up and see if it runs smoothly, any jumping in the needle or noise disconnect the cable so it won't do any major damage and have it repaired.
  11. Duke
    Duke
  12. Pav8427
    Pav8427
    Nice. Now when you hit a buck fiddy you can prove it to all your buddies.
    SS327 likes this.
  13. Duke
    Duke
    68676748673__F0D0E06B-2BEB-4567-BB08-668223331D4C.jpeg 74188318192__F1572777-5BF9-4C99-BA8C-26AAD7E142F7.jpeg 74188325926__C8BD624B-DA58-41F9-B089-1924D4E22110.jpeg /ATTACH] I followed the test procedure that @e1956v gave me above and I had some issues. Lots of noise and the needle jumped around. I sent it to e1956v and he quickly got it running like new again. Here are some shots on his test and calibration machine. Thank you Rusty for getting this done quickly and very affordable. I highly recommend Rusty if your speedo needs a service.
    pprather, 51504bat, Budget36 and 2 others like this.
  14. e1956v
    e1956v
    Alliance Vendor
    Thanks Duke
    I was able to get calibration close in the lower speeds up to 70 then after 80 it starts to read 4 mph slow. If I got it closer above 80 it sacrificed accuracy in the lower speeds. So I always shoot for the lower speeds below 60 to be the most accurate.
    I really appreciate you trusting me with your repair.
  15. Duke
    Duke
    Thank you, that makes sense. If I am over 80, I am already speeding so how much doesn’t really matter :)
    SS327 likes this.
