Technical Questions regarding '32 chassis
Discussion in 'Traditional Hot Rods' started by Joe Altieri, Jan 20, 2016.
  1. Joe Altieri
    Joe Altieri
    I am considering buying a hotrodded, '30-'31 Ford tudor sedan that is in need of a new ch***is. I would like to know if it is possible to use a '32 ch***is while retaining the Model A fenders. I would like to use the '32 ch***is because of its' strength and the simplicity of mounting a '32 gas tank. If you have any comments or information about this swap, I would greatly appreciate hearing from you.
    Thanks.
    joe
    josephaltieri@att.net
  2. X38
    X38
    Apart from the common enough solvable issues of mounting the A body on the 32 ch***is - both ch***is and body work - mounting fenders and running boards present further issues due to the shape of the deuce frame, difference in wheelbase etc. It can be done, with plenty of work.
    You can put a square peg in a round hole if you are capable of modifying the either the peg, the hole or both.
    There have been threads about this before, so take a look at the search function for possible help.
  3. HOTRODPRIMER
    HOTRODPRIMER
    No,but you can guy a repro frame that is already boxed and is a strong frame. HRP
  4. 49ratfink
    49ratfink
    just talking out of my **** here but it seems like it might be easier to use 32 fenders....
  5. Bruce Lancaster
    Bruce Lancaster
    Yeah...'32 fender$$$, at least up front. Look at the mounting flange on A front fender; notice that the 31 frame in that area is wider and shorter than '32 at front of flange, narrower than '32 at back of flange, and note that the '31 fender also has a bulge out to meet the apron area on a Model A...which will be hanging out in the breeze on the apronless '32.
    In back...at first guess...you will need to extend the apron area over to find the '32 frame and probably cut back the similar area where fender will hit the '32 frame. Probably rear is much easier than front.
  6. krylon32
    krylon32
    from Nebraska
    Years ago at many of the national events there was a red 30/31 roadster on deuce rails that was running 32 fenders/ running boards/gas tank/frame horn covers and bumpers.
  7. pprather
    pprather
    For starters, think about a stock '32 has a 106 inch wheelbase, the Model A wheelbase is 100 inches.
  8. 31Apickup
    31Apickup
    Besides the fenders being an issue, you'll have to cut and rework the rear body subrails including the lower rear, that is why the 32 horns are usually bobbed off on A's on 32 frames
  9. Joe Altieri
    Joe Altieri
    Thanks for your comments. I have, twice in the past, done that. It was a bit of a pain to fit the '32 tank to the aftermarket ch***is, but it did work out well.
    From whom would you buy a new ch***is? I have used TCI in the past,
    joe
  10. Joe Altieri
    Joe Altieri
    Thank you for your comments. I think you have helped me make up my mind Not to try to do the '32. It would be a no brainer if I was doing a highboy.
    joe
  11. rusty rocket
    rusty rocket
    You can also do a 32 tank on the back off your A ch***is takes a bit of work but doesnt look to bad.
  12. Just Gary
    Just Gary
  13. Dino 64
    Dino 64
    from Virginia
    Brookville Roader makes one as well. There are lots of them on eBay from various ch***is builders.
