questkion about a ford inline six.
Discussion in 'The Hokey Ass Message Board' started by gearhead55, Jun 3, 2013.
  1. gearhead55
    gearhead55
    from philly
    Should the flywheel on a 250 out of a 69 mustang have a weight?
  2. hoop98
    hoop98
    from Texas
    Should be zero balance.
  3. kracker36
    kracker36
    The 200 and 250 are internally balanced and should have no weight on the flexplate/flywheel.
  4. Ebbsspeed
    Ebbsspeed
    I think kracker36 meant "should have no weight on the flexplate/flywheel"
  5. kracker36
    kracker36
    We have a hard time spelling in Kracker Station Mississippi! ;)
  6. gearhead55
    gearhead55
    from philly
    Ok but this thing is vibrating like a son of a *****
  7. Phil1934
    Phil1934
    In neutral,or just at speed? Speed only could be driveshaft.
  8. gearhead55
    gearhead55
    from philly
    It vibrates at idle as well
  9. gearhead55
    gearhead55
    from philly
    Neutral driving the worst is in gear on the brake
  10. R Pope
    R Pope
    No straight sixes ever used weights.
  11. gearhead55
    gearhead55
    from philly
    Hmmmmmmmmm. Any ideas fellas? Ford novice here.
  12. need louvers ?
    need louvers ?
    You have already been answered a couple of times. It's a Zero balance fly wheel. I other words, no it won't have an external weight on the flywheel or flex plate. If it does, then someone has put a small block flywheel on iy and it will vibrate like nobodies business.
  13. GTOMUSTANG
    GTOMUSTANG
    from ct
    from what I remember, the early 6's didn't run harmonic dampeners, and thus got a vibe running down the crank after 5500RPM.
  14. mustangsix
    mustangsix
    A 289/302 157 tooth flywheel is the same diameter as a 250. It they bolted that on, the engine will shake like a vibrating bed in an hourly motel......
  15. Six cylinder inlines are all internally balanced.
  16. gearhead55
    gearhead55
    from philly
    There is no weight on the flywheel and it still vibrates at idle
