Hot Rods Quick 32 full fender Ford question
Discussion in 'The Hokey Ass Message Board' started by metalman, Dec 2, 2022.
  1. metalman
    metalman
    Hey guys. I have a buddy's full fender Vicky here. Front tires are 205 75 15s on 4 1/2" wide Wheel Vintiques stock look rims. Tires look too big plus a lot of rubbing. I hate to raise the car any for mre tire clearance, I like the stance. What size tires are you all running?
  2. X38
    X38
    I would have thought 165/75/15 on the front. (used to be Michelin XZX)
  3. HOTRODPRIMER
    HOTRODPRIMER
    I totally agree! HRP
  4. swifty
    swifty
    That's what I was running when I first got my 32-5 window on the road (take offs from son's 32 roadster ) I think they were standard for VW Beetles. And back in the 60's Pirelli and Michelin were the only tire companies making radials.
  5. chop&drop
    chop&drop
    A 165R-15 would be approximately 1-3/4” shorter and 1-1/2” narrower than the 205’s and should look just right.
    RICH B likes this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Today one has to ask for 165/80/15
    bschwoeble and Just Gary like this.
  7. pprather
    pprather
    I run 165/80/15 on my highboy roadster.
    bschwoeble likes this.
  8. Hoptup32
    Hoptup32
    I'm running 185/70/14 on the front of my 32, no rubbing issues. 14-inch rims do limit the size of disc brake caliper that can be used, due to clearance issues.
  9. 38Chevy454
    38Chevy454
    There are also 155R15 (155/80R15) and 145R15 (145/80R15) sizes if you need a little smaller. The 145 are common on non-fendered roadsters for fronts. A 135 is too small for a fendered car.
  10. twenty8
    twenty8
    A 205 tire is too wide for a 4.5" wide wheel. The sidewalls will be bulged too much which can lead to poor handling, bad wear, rolling a tire off the rim, and the possibility of failure due to the extra heat generated in the tire.
    The 165R15 (OR 165/80R15) is the widest you should run on a 15" x 4.5" wheel.
  11. Happydaze
    Happydaze
    I like the look of 145's, whether fendered or not, but the performance in terms of ride quality and cornering ability of 165's is most noticeable.
    Chris
    Just Gary likes this.
  12. da34guy
    da34guy
    145 sr 15 on all mine with or with out fenders 2022 tan 32 Dr P wall side.jpg
  13. metalman
    metalman
    Thanks guys, think I'll order up some 165s.
  14. uncle buck
    uncle buck
    To throw a twist in the subject, anyone with experience putting a 165/80-15 on a 15x6 wheel?
  15. pprather
    pprather
    My 165/80-15 are on 15x5 wheels.
  16. twenty8
    twenty8
    Recommended Rim Sizes
    and Rim Widths
    for Tyre Size: 165/80 R 15
    Min Rim Size 4.0" x 15"
    Max Rim Size 5.5" x 15"
    Min Rim Width 4.0"
    Max Rim Width 5.5"
    Rim Width Range 4", 4.5", 5", 5.5"
    Measuring Rim
    Width 4.5"
    Standard
    Rim Width 4.5"
