quick adjuster spring ?
Discussion in 'The Hokey Ass Message Board' started by misfit36, Feb 12, 2008.
  1. misfit36
    misfit36
    from new york
    ok just did my front brakes ( new wheel cylinders, springs, hold down kit, adjuster stars, hoses, shoes and linings) when i put on the adjuster star and spring, the spring is sitting on top of the adjuster not like the photo below of one of the brakes where the spring and star "mesh". my question is if they are supposed to mesh, which i believe so, and how to get them to "mesh" without taking everything off. thank you for the help, this is my first brake job.
  2. rusty1
    rusty1
    ...usually that spring has a strate section on one end, that end goes towards the star wheel end and clears the star wheel so as not to interfere with the star wheel. You sure you have the correct spring there?
  3. misfit36
    misfit36
    from new york
    pretty sure. ill be in my "garage" tomorow, ill take some pics. thanks for the help.
  4. misfit36
    misfit36
    from new york
    here are some pics
  5. jetmek
    jetmek
    what rusty 1 says is true if they are the self adjusting type brake which yours doesnt appear to be in which case the spring rides on the starwheel as yours does to keep the adjuster from backing off.
  6. racer32
    racer32
    Misfit, you need to get that grease out of there-it's not good for the shoes when it gets on them.
  7. misfit36
    misfit36
    from new york
    i knew that they are supposed to sit on top of the star, i wasnt sure if they are supposed to mesh like the old ones are doing in the first pic. thanks for the help. as ar as the grease goes, someone told me to use white lithium grease where there are points of friction(obviously not on the linings). is there a chance that it could get on the shoes? where should i grease? thanks for the help guys
