Technical Quick BBC Question
Discussion in 'The Hokey Ass Message Board' started by blown240, Mar 16, 2022.
  1. blown240
    blown240
    from So-cal
    WOW! So much info here. Thanks for all the replies.
  2. Grimpala
    Grimpala
    from DFW
    Gen V did away with the boss and went to non adjustable valve train(moot point with the Edelbrock heads), Gen VI had the the fuel pump boss re-introduced.
  3. chevy57dude
    chevy57dude
    Worth knowing is Mark IV and Gen 5 oil pans do not interchange, probably due to the one piece rear seal on the newer blocks. Also it is possible to install a Mk IV crank in the later block with a seal adapter. Gen 5 has improved oiling and the blocks are tapped for oil cooler lines.
  4. gimpyshotrods
    gimpyshotrods
    I gave up on modern stuff in that era, save for the dreaded LS.
    Has to be a Gen VI block then. It should have a roller cam. In his case it might be worth seeing what cam it actually is, since someone has been doing some work on this thing.
  5. squirrel
    I think the timing cover tells us it's the later block, too.
  6. swade41
    swade41
    from Buffalo,NY
    Early Gen VI didn't have the provision either, it was like mid year or something
    gimpyshotrods and Desoto291Hemi like this.
  7. swade41
    swade41
    from Buffalo,NY
    That's the second one I've had, Tonawanda foundry guys screwing around, here's the other
