Hot Rods Quick change question
Discussion in 'The Hokey Ass Message Board' started by hfh, Sep 19, 2025.
  1. hfh
    hfh
    from Western MA
    I need to add lube to my Halibrand quick change and am looking for guidance on the best lube to use. And is it okay to just add more or should I drain everything and start fresh? Thanks for any comments. HFH?
  2. jaracer
    jaracer
    Any 80 or 90 weight is good. When I was racing we use Lubrication Engineers 90 weight gear lube. It is red and stains anything it touches. However, it cuts down the gear temperature significantly. I'd watch guys in the pits changing gears and they would almost be smoking after a 10 lap heat race. It was all they could do to handle the gears. My gears were hot, but not too hot to handle. I still use it in my cars (non quick change).
    patsurf, loudbang, Xman and 5 others like this.
  3. hfh
    hfh
    from Western MA
    Thank you!! And thanks for adding your great story.
    hrm2k likes this.
