Hot Rods Quick Change, Quickchange
Discussion in 'The Hokey Ass Message Board' started by GearheadsQCE, Nov 11, 2014.
  1. ago
    ago
    from pgh. pa.
    I agree with that. Running Winters track is real nice on the street
  2. jseery
    jseery
    from Wichita KS
    OMG, I couldn't believe how difficult my dirt track car was to just push around on the driveway with a spool. Soft tires, a spool and tire stagger, impossible to move!!!!
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Same with my drag car. Just asking to see if he has come to that realization yet. ;)
  4. bone31
    bone31
    just did a thread on a build from start to finish on my qc's thread is mctim64 flathead roadster IMG_1175.JPG
    jebbesen, youngrodder1929 and Avgas like this.
  5. bone31
    bone31
  6. bone31
    bone31
  7. bone31
    bone31
  8. 69fury
    69fury
    from Topeka
    I ran a spool in my 69 Plymouth on the street for over 5 years, with big sticky tires out back. Yes, it tried to crab a bit when backing out of parking spaces and the front tires cranked hard, but it was a minor thing- made me giggle more than anything else. I wouldn't do a spool for my daily driver, but for a cruising/strip car, it's something i really dont mind putting up with.
    I found the pics showing it as received from Frankland's rebuild. Shown in front of my friend's 9 inch for size comparison for those that don't know quickchanges...
    One thing to note- the Jones mag bells do not accept the axle tube as deep as the Franklands (by 1/2" each) so plan accordingly when measuring out your flange to flange width.-rick
    Quickchange012.jpg Quickchange014.jpg Quickchange012.jpg Quickchange014.jpg Quickchange015.jpg Quickchange016.jpg Quickchange018.jpg
  9. Work4it
    Work4it
    GearhedsQCE,
    I went out and measured everything I have, the tubes and axles have about an inch difference.
    The long axle that looks stock is 33-5/8" from flange sealing face to tip of axle, the splines start about 3/16" from the end.
    The short axle that looks like it has been welded right next to the splines is 32-5/8". The splines have been stripped off about 5/16" from the end and seem to taper, they are rough. I would not use this axle.
    If my calculations are correct my set up will be 62-1/8" from WMS to WMS, my drums are behind the hubs.
    The distance on my hubs from the flange mounting surface to the wheel mounting surface is 6-3/8". The axle tube sits inside the axle flange surface 1/4".
    It will be too wide for my project.
    I got my Ruskin/Frankland aluminum drums today, they are very cool. One is not usable so if anyone out there has some they want to sell I would be interested.
    Are any of these bearings and seals obtainable at bearing houses?
    My hubs had FOMOCO seals in them, I found that interesting.
  10. Work4it
    Work4it
    Thanks ****gy,
    I think I may end up using double sliced axles due to width.
    I drove through your town earlier this winter, small world.
    Going to the Early Bird swap meet?
  11. Shaggy
    Shaggy
    from Sultan, WA
    Nah I'm putting the l79, m22 in my daily this weekend, so I wont even have time, and I don't even have anything that I'd trust that far since I'm borrowing a beat to hell old f-250
  12. Tudor
    Tudor
    from GA
    Ago- Just ordered a Winters Track - Glad to hear it's good in your opinion. Would like to hear some more of your experience with it. Does it need a modifier?
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes, all the bearings and seals can be purchased at bearing suppliers. I have found that the rebuild kits from the QC makers are comparable in price to the bearing houses. I can help you with these.
    I have found many axle tubes with the original seals in them. I think that the tapered tubes and bells do a very good job of keeping the gear lube away from the outboard bearings. (Not in the right side of a circle track car)
  14. ago
    ago
    from pgh. pa.
    Tudor,
    No, you don't need a modifier. Winters told me to use Mobil 1, 75-90W gear lube. I have not had any problems in 14,000 miles running the QC. Drained and checked for slivers, NONE. doesn't run hot etc. Just a trouble free set up, little noisy but real cool noise. love it.
    Dave
  15. Work4it
    Work4it
    These large qcs are big, they look kind of bulky under hot rods, but I will be using this one under a Studebaker coupe anyways. It is what I could get my hands on. I like the idea of using this older unit vs a brand new smaller looking unit. Definitely trade offs.
    It is a money pit, it should have a slot in the top for $100 bills.
  16. Work4it
    Work4it
    So who is running wide fives on one of these?
    My old dirt hubs had 1/2-20 studs with 7/16" shoulders, I just figured they would be 5/8 like the modern hubs. So I figured I would have to run a 15" race wheel, is that what is being done? I plan to run Ford wide fives up front but unsure what to do in the rear.
    It will have a mild small block Ford and I originally wanted to run 750-16s on the back before I went to a quick change. I then thought I would end up with a 15" wheel and was trying to figure out what would look good for a tall tire, don't want big meats on back.
    Has anyone worked through this issue with good solutions?
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    As far as I know, all the modern wide 5 wheels are drilled for 5/8" studs and the seats are for 45 degree taper. The narrowest I could find for my truck were 8".
    I think you will have to get original Ford wide 5 wheels and possibly have them widened. This will give you the proper hole size and lug nut taper. I believe that the widest is around 4 1/2". (could be wrong on this)
    Rule of thumb, wheel width should be 1" less than tire cross section + or - 1". So, wheels with 7.50 tires should be 6 1/2 - 7 1/2" wide. I know a lot of people will tell you they have run very wide tires on 4 1/2" wheels but the tire manufacturers do have a recommendation for every size tire.
  18. Shaggy
    Shaggy
    from Sultan, WA
    Some of the old ones are too, anyone have the part number for those studs on a frankland hub? most i can find dont have enough knurling
    There is an optional/lincoln/truck or whatever wheel that is 5" but it's pretty rare, and it isnt the spoke look. I have 2 and i'm looking to do a set, and it's taken me years to find them. There was an artical on here a bunch of years back about I believe GM commercial wheels in 16x6.5 having the right hoop diameter, the only problem is they arent a standard hoop/center design instead the center is also the front bead of the hoop
  19. Blue One
    Blue One
    from Alberta
    Seems you were flat out ignored on this thread. :confused:
    Very nice work, Tim is lucky to have one of your QCs
    mctim64 likes this.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes,
    Sorry about that, Bone.
    That is a fine piece of craftsmanship. I was going to try building my own when I retired. That's going on 5 years now, and I still haven't caught up on my projects enough to start another. But, I do have the pieces waiting in the wings.
    Didn't catch the tread address the first time around.
  21. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Sorry, I still can't find the thread.
  22. Blue One
    Blue One
    from Alberta
  23. Work4it
    Work4it
    Bone's work is awesome, I had not been able to get to the thread. There is a lot of p***ion in each one those.
    The only studs I have found so far are at;
    http://www.jegs.com/i/Moroso/710/46420/10002/-1?parentProductId=
    I am not sure the knurl is long enough as ****gy stated. They even say they are for thick Frankland hubs.
    I can widen my wheels, I would need to find some old school looking 16s that fit them.
  24. 26 roadster
    26 roadster
    I need 23.5" axles cut for my QC. measured from wheel flange to end. My local guy retired and no one locally will cut 12 spline axles. Any suggestions that are close by? I have the axles and just need them splined.
  25. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Moser Engineering. 2 day turn around, reasonable prices. Tell them Gearhead's Quickchange Exchange recommended them.
  26. Gene Boul
    Gene Boul
    I want one for my 38...but after I finish the F1 project. Great thread...
  27. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Thanks Mark for posting that. That address on the side of the case is exactly where these shots were taken, Not many shops are still in their original location. Cook's made that raw casting about 1947. We have 2 un-machined cases/covers. The Halibrand (KS.) shaft is one of the last that Mike made who worked there yrs. back before their re-structuring. As you can tell and Stovebolt pointed out, its about 2 inches shorter on the coupler end, have no idea why, It's just what it is.
    Stovebolt took pix of my 32 years ago with Cyclone #16 in it. The 32 runs the stock tank, a 32 Rear X-member from the near dip to the to the rails, In the center of all this is a Model A center X-member tying it all together to clear the Cyclone. I thought I came up with the idea years back, but alas, looking over the Pierson Bros 2d coupe It has a very similar set up ;).
    The drive shaft is 47-1/2" in length splined end to splined end, The coupler goes right on and has no issues. It's been so long since I cut the torque tube that I can't remember perhaps 51"? We've done perhaps 4 of the drive shafts for customers who saw the Cook's/Cyclone unit and all fit as designed.
    It's been a long road for me just to get to be able to drive my 32 with a unit installed as I never get a chance to get my stuff done. :/.
    I hadn't seen this post before, was actually looking for the post on Mike (Bone31) building that kool kwikie out of a banjo. I like how he built that whole deal and feel he's amazing! Man, That's talent!!!
    Normally, I have Paul @ Cook's spline the shafts, but they're pretty busy doing the driveline/rear end stuff for drag racers, low riders, off road stuff and other mfg.'s. I'm working on splining them myself on the Bridgeport, but that 4340 chrome moly is a killer on cutters.
    It was good to see this ;).
    CK
    Drewfus and Stovebolt like this.
  28. blackout78666
    blackout78666
    Just finished putting together my first quickchange. A 201 with 48 ford tubes, 40-48 ( corrected. Thought it was a 3/4 ton unit, thx BD) 28 spline open carrier and big ford axle flanges . image.jpg I've checked through all of the quick change threads and didn't see anything about how to narrow and align the axle flanges so I made these. 3/8 x7" alum line up plates for 201,301,and frankland/ winters image.jpg These follow the radius of the QC housings and bolt inbetween axle trumpets and QC centersection
    image.jpg These align the tubes and centerline of the carrier so you can run an alignment bar with collars through the whole ***embly provided it's not a spool. Squared edges help too to keep the rear from floppin around.
    Bolt the other plate on and install the ends , I had to. Turn em down a little to fit but not much. Fit the slugs in and tighten up the collars and double check everything!
    image.jpg Then turn up your welder and stick em on.
    image.jpg That's it. Like I said this is my first one but I find these fascinating. Much thanks to dennis frings for answering my endless questions and QCE as well for insight. Hopes this helps someone. Jay
    IronFord, volvobrynk and Pewsplace like this.
  29. big duece
    big duece
    from kansas
    Any pics of the 3/4 ton 28 spline open carrier, and year of vehicle used?
  30. big duece
    big duece
    from kansas
    2014-09-25 21.21.17.jpg 2014-09-25 21.22.08.jpg You can also use one of the axle bearings and a special made collar to use the alignment bar for that type of bell work.
    Pewsplace likes this.
