quick change rear end lower shaft id?
Discussion in 'The Hokey Ass Message Board' started by titus, Apr 18, 2010.
  1. titus
    titus
    I picked up some lasalle transmission bits yesterday and this lower shaft was in the box of parts, so im trying to id it, the over all length is closely roughly 20" and the bearing snap ring groove to bearing snap ring groove is 13.875 roughly, and the rear ward pilot dia into the rear cover is .8125, and the shaft diameter where the bearing rides is roughly 1.125 and the over all dia of the one bearing thats on it is 2.835 and the number on the bearing is 6306j30.
    any help would be great
    thanks
    jeff
  2. dirty old man
    dirty old man
    How many splines on the ends?
    Dave
  3. lakes modified
    lakes modified
    Could be Halibrand or Frankland or?.
  4. titus
    titus
    6 splines on both ends
  5. dirty old man
    dirty old man
    Six (6) splines mean that's a shaft from what's known as a "V8" Q C center section for use in a passenger car or 1/2 ton p'up rear rather than the "Championship" rear which uses 3/4-1 ton gears and has 10 splines.
    As to the maker, or brand, unless it's stamped on the shaft, it's unlikely you could ascertain this just strictly from measurements without having all those measurements from all the others, if then.
    Most likely these parts interchange pretty much across the board, as the makers were all copying Hallibrand and Frankland anyhow!
    Dave
  6. thunderbirdesq
    thunderbirdesq
    Dang, I coulda used that a while back!;)
