Customs Quick coolant leak question
Discussion in 'The Hokey Ass Message Board' started by SoCal52Deluxe, Jul 20, 2014.
  1. SoCal52Deluxe
    SoCal52Deluxe
    I know some HAMBers out there are familiar with these, just curious if the pet**** valve shown in the picture is reverse threaded into the bib (I'm sure it has a real name). Can't find any mention of this part in the manual. It sends coolant from the water pump to the heater hose. I have a leak where the pet**** attaches to the bib, not where the bib goes into the motor. I tried tightening it but it didn't budge Water bib.JPG so before I put my weight behind it I wanted to see if it was reverse threaded... Thanks
  2. ROADSTER1927
    ROADSTER1927
    I never had one that was reverse threaded, so I bet not! Gary
  3. SoCal52Deluxe
    SoCal52Deluxe
    Thanks Gary, I'm gonna pull it out and drop it in the vise
  4. HOTRODPRIMER
    HOTRODPRIMER
    I believe the old right to tight is the correct way. HRP
  5. SoCal52Deluxe
    SoCal52Deluxe
    HRP and Gary are correct, standard thread it is! After a little thread tape and tightening I reinstalled the bib. Fired it up and it still leaks :(
    Upon close inspection I see the leak is actually coming from the threads of the pet**** stem itself, just outside the nut.... Perplexed on a solution here
  6. 302GMC
    302GMC
    from Idaho
    It's an add-on valve. The packing is under the br*** nut - shimming or repacking will fix it ...
  7. squirrel
    You won't find that in the manual, since it's not an original part. Someone added it.
    I just run a normal Chevy fitting that doesn't have a valve.
  8. SoCal52Deluxe
    SoCal52Deluxe
    Makes sense guys, looks like it's gonna take a trip to NAPA tomorrow to square it away. Thanks for all the replies, I swear this thing will be on the road before summers end!!
  9. SoCal52Deluxe
    SoCal52Deluxe
    Replaced the valve with a standard stem, no more leak. Thanks for the wisdom fellas!
