quick model T rear spring question
Discussion in 'The Hokey Ass Message Board' started by trestles126, Feb 23, 2010.
  1. trestles126
    trestles126
    tryin to figure out if my rear spring is a model a or model T spring
    it measures roughly 17 inches tall from ground to top of bell, and 40-41 inches wide eye to eye
    any quick replies will be appreciated searched but came up with pages upon pages of vague answers
  2. thunderbirdesq
    thunderbirdesq
    It's all in the shape, T springs are also only 2" wide, A's are 2.25"...
    A quick google search yielded these results...
    Model T...
    Model A...
  3. Nobodys Hero
    Nobodys Hero
    from New Jersey
    Yup, thats a T spring
  4. GZ
    GZ
    from Detroit
    Another tell-tell sign is the Model T spring (unless made before 1918) will have a small hole on the main leaf on top of the shackle eye. Prior to 1918, a Model T rear spring will be of the tapered leaf variety and will not have this hole but will have the nice, rounded tapered leafs. Model Ts built from 1909 to 1918 had oilers in the shackles. After 1919, the shackle oiler was eliminated and a small tin oiler was pressed into the hole on the main leaf. The Model A rear springs (and fronts) do not have this hole as the shackles had the grease fittings. The T springs is also shorter top to bottom and a little bit longer in overall width (end to end), and, like stated above, is 1/4" thinner.
