Technical Quick question about 61 Olds steering box
Discussion in 'The Hokey Ass Message Board' started by 57JoeFoMoPar, Feb 19, 2022.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    Guys, dumb question.
    1961 Olds Super 88. I think this box also interchanges with Olds up to 1966 but this is a 61.
    Which port on the steering box is the high pressure in and which is the low pressure return? These got marked when I took this thing apart 2 years ago but the marks got worn off and now I forgot. I think the upper port, the one closer to the rag joint, is the high pressure in and the lower one closer to the engine is the low pressure return, but I don't remember for sure.
    Also, this is not a factory application. This is not the factory engine, nor the factory PS pump or hoses, so those references are not available.
    If anyone could verify this for me I'd great appreciate it.
  2. Mr48chev
    Damn, I am supposed to know that answer off the top of my head but it has been 40 years since I worked on those models. The larger one should be the pressure side and the smaller one should be the return if they have different size fittings.
    57JoeFoMoPar likes this.
  3. kadillackid
    kadillackid
    This is same period years
    Cadillac, but should be the same....
  4. 57JoeFoMoPar
    57JoeFoMoPar
    The port closer to the engine is the larger port, which would be the same as the diagram provided above. So I might have had this backwards in my head
