Quick question about a possible faulty master cylinder
Discussion in 'The Hokey Ass Message Board' started by Scallop, Jul 1, 2008.
  1. Scallop
    Scallop
    I am bleeding the breaks on my truck to try to eliminate a spongy pedal the and I also needed to replace the wheel cylinders in the rear, but my question is that when the break line is disconnected it drains all of the fluid from the system right down to emptying the master cylinder so I was wondering if maybe my master cylinder is bad and therefore causing my spongy pedal.
  2. RoadsterRod1930
    RoadsterRod1930
    from NEPA
    it could be the master cylinder. if you pump the pedal very fast do you get pedal for a second then lose it? what vehicle are you exactly bleeding./
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    A bit more info needed. Single or dual M/C? drums or disk drums? If M/C is above the end of the line it is possiable for them to drain by gravity.
  4. Scallop
    Scallop
    This is for a 97 silverado, it's OT so I didn't include that but it's disk/drum.
  5. phat rat
    phat rat
    A disconnected line will drain the master. Also you need to replace the rear wheel cylinders if their bad before the pedal will feel right
  6. Scallop
    Scallop
    I am only replacing the rear cylinders because the bleeders are seized I don't think they are bad thou, but I was concerned about a bad master cylinder when I saw it draining like that it made me think that the seals might be bad in the master cylinder.
  7. The Wolf
    The Wolf
    from OAKLAND CA
    yup. pump the breaks a bunch. if you get a still pedal then it bleeds off to the floor............... bad master cyl!
  8. Black Magic
    Black Magic
    Put some Koil on the wheel cylinder bleeders and it should free them up.
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Draining like that does not mean the M/c is bad. Get the rear W/C issue fixed and then if you still have a spongy pedal start looking at the M/C . Those damm dual cylinders tend to fail fairly often IMHO! In 9 years and 180K I've replaced 3 on my 94 Ranger.
  10. Scallop
    Scallop
    HA! You need to come up here to the land of rust I couldn't get them lose even after letting them sit for a few days with penetrating oil and a pipe wrench or the vise grips that I used as a last resort so for the $13 it cost for a new wheel cylinder I just got them instead.
  11. Black Magic
    Black Magic
    If they are that bad I would also pay the $13 for them.
  12. tommy
    tommy
    If you let all the fluid drain out, you may need to bench bleed the M/cyl again to get it back to snuff just like starting with a new dry one in the box. If air was able to enter the piston, you'll have to start over again. I never liked gravity bleeding for this reason. If there was fluid still in the reservoir then you are probably ok.
  13. billbrown
    billbrown
    if you pushed the pedal all the way to the floor it is very likely that you floded the seals over.Your spongy pedal is probably form air trapped in the system. Go to autojoke and buy a pressure bleeder. You will save way more in brake fluid than you spend on that tool. Bleeding stuff sucks.
  14. Black Magic
    Black Magic
    The bleeder is totally worth the price.
  15. Scallop
    Scallop
    Well I just finished bleeding the brakes and installing the wheel cylinders but I still have a spongy pedal, I tried pumping up the breaks a bunch to test the master cylinder but it still doesn't have much pressure. I started up the truck to get some pressure in the booster but with the truck running the pedal slowly goes to the floor.
  16. JohnEvans
    JohnEvans
    from Phoenix AZ
    BAAAAAADDD M/C !!!! Typical of how they act.
  17. Black Magic
    Black Magic
