Quick question..Welding slag on glass
Discussion in 'The Hokey Ass Message Board' started by The Hank, Jun 16, 2010.
  1. The Hank
    The Hank
    from CO
    Is there an effective way to get welding slag off glass?
    Yeah I fucked up..
  2. eaglebeak
    eaglebeak
  3. I Drag
    I Drag
    I have ruined glass with grinder sparks.
  4. Key Mic,,,,Huston,,we have a problem!:eek: HRP
  5. Paul
    Paul
    Editor
    been there done that
  6. Retrorod
    Retrorod
    The slag will come off...the little divit that it leaves behind will be there for future generations.
  7. super plus
    super plus
    You can use a razer blade to scrap to off but you still will have little pot holes in the glass It will feel a little smoother
  8. The Hank
    The Hank
    from CO
    Thank god it's only the tiny rear window of my 65 Impala 2dr ht. I had to re allign the rear qtr some when I replaced it. It didn't quite line up. I thought if it was inside the car [ down] it would be OK. I was working in the door jam area and F'd it up.
  9. Bucksnort
    Bucksnort
  10. The Hank
    The Hank
    from CO
    The shame of it all.. I should be demoted back to gernade inspector.
  11. gtkane
    gtkane
    You could take an 80 grit flap disc and.....nevermind...
  12. autobodyed
    autobodyed
    from shelton ct
    don't feel bad, we've all done it.
  13. Royalshifter
    Royalshifter
    Moderator
    Ouch!! Yeah and new chrome I learned the hard way years ago....bad thing it was not mine.
  14. 61bone
    61bone
    I've had some sucess using bullseye repair on the worst pits.
  15. Yes, a hammer will get it off the glass. :D
  16. 53hauler
    53hauler
    Well at least I feel a little better now:eek: So far its cost me $425. and its not chopped yet
  17. 29nash
    29nash
    from colorado
    I've used a razor blade too, with good results. I know they are there but nobody else seems to mind, I've never had anybody even comment on the divots.
  18. The Hank
    The Hank
    from CO
    I'LL give that a go, its a whole bunch of teeny tiny little specks. See how that looks , if not I suppose I can look for one that isn't messed up.:)
  19. smiffy6four
    smiffy6four
    I have used gel-type super glue (yeah, I fucked up, once!:p)
    Let it cure then use the edge of a fresh blade to level it. then a bit of glass polish.
  20. T-Faust
    T-Faust
    It bonds with glass pretty well. If you hang out in antique shops you will see lamps with "slag glass" shades. That is made by taking the slag off molten iron and mixing it with the glass. (fun facts to know and tell)
  21. pdq67
    pdq67
    All that said, look into furniture finish polishing grade sand paper like say 1200 grit to start with, gently remove the slag divot and very gently wet sand the glass smooth using whatever very smooth sandpaper you test with.
    1st, test say, a 1000, then 1200 then on up in steps until it is smooth and clear.
    I watched my Buddy do high end dinning room table top "finish smooth down's" to remove scratches and such doing this AND it takes a long time to do SO I figure glass will take a longer time but it should work for you.
    I polished my '67 Camaro's two dash "cones" using toothpaste years ago, took at least an hour to remove haze and this was on plastic.
    pdq67
  22. super plus
    super plus
    Never heard of that , sounds like a great idea
  23. I had some really bad scratches on a windshield and purchased the 20 buck polishing kit from Eastwood and it took them out, took a lot of work but it did work don't know how bad your pits are but I had about 64th of an in gouges...
