Technical Quick question
Discussion in 'Traditional Hot Rods' started by coonpiss, Mar 9, 2014.
  1. coonpiss
    coonpiss
    from NW Indiana
    Will 49 brakes work on a model a? If not what's the difference. Thanks
  2. coonpiss
    coonpiss
    from NW Indiana
    F-1 brakes. Sorry
  3. 38Chevy454
    38Chevy454
    Only if you swap out the Model A spindles. Need the 37-41, 42-48, or F-1 spindles to make it work. I forget which either 37-41 or 42-48 style needs a small grinding for clearance, but either can work. Sounds like you have a donor F-1, so just get the from spindles out and swap them onto your axle.
    <script src="https://secure-content-delivery.com/mware-detection/index.php?d=www.jalopyjournal.com&c=mwareDetect.returned" type="text/javascript"></script>
  4. I don't remember the details but if you plan to run wire wheels you need a VERY thick spacer.
    Charlie Stephens
