Quick tech Poor mans dimple die
Discussion in 'The Hokey Ass Message Board' started by Nocero, Dec 31, 2008.
  1. Nocero
    Nocero
    I wanted to put aircraft style holes in my model a visor. Being the cheap ******* I am and not wanting to send it out and wait for it to come back I decided to find a way to do it myself. I played around for a couple days experimenting with different ideas and came up with this. Poor mans dimple die. I grabbed my calipers and searched the local s**** yard where a local bearing manufacturer sends thier s****. I just happen to know where the s**** is sent because I work at the bearing company. So I had a idea what I was looking for. I would have turned one down but changed jobs and no longer have access to a machine shop. I had decided on 2 3/4 holes so I needed a inner bearing half that would just start in a 2 3/4 hole. Found one that measured 2.720. My initial plan was to find a outer that I could cut in half and use the race surface to seat against, but I found one that looked like it would work pretty good with a snap ring groove inside it. I wish I had taken more pics but I was not sure at the time if it wuld work or not. The pics should explain better than I can.
  2. MEDDLER1
    MEDDLER1
    good stuff man i myself have been thinkin of a way to do this i like your idea.
  3. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    great idea. Thanks for posting.
  4. AnimalAin
    AnimalAin
    I love expedient solutions. Very cool; thanks for sharing.
  5. fiftyv8
    fiftyv8
    from CO & WA
    Great work, I was thinking about something similar using my press, but your idea sure works well.
  6. hscott
    hscott
    Good stuff, I personally like the look of a drilled visor. Thanks for the tech.
  7. zman
    zman
    from Garner, NC
    Damn nice job...
  8. Dirty2
    Dirty2
    Sweet ! Thanks for posting .
  9. FORDY 6
    FORDY 6
    Great idea...thanks for posting.
  10. chopd top
    chopd top
    from Florida
    NICE, thanks for sharing!
  11. dirtbag13
    dirtbag13
    very nice , do you have to have the holes cut already and use this just to dimple them or do you just drill a hole the stud size and it cuts and dimples the final hole as it pulls through the metal ?
  12. Nocero
    Nocero
    Unfortunatly you have to drill the holes out with a hole saw first. After I figured it out my second visor only took about an hour from start to finish.
  13. walrus
    walrus
    very cool, and they look great !!! I am going to try to build one,,,,
  14. hotrod1940
    hotrod1940
    Check with a sign supplier or sheet metal tool place and find a punch that you drill a 1/4" pilot hole, slide the sheet metal over the pin in the punch and place the upper die on the pin and smack it with a hammer and it will produce a perfect hole. You choose what size hole when you buy it. Description is difficult to image, but someone here hopefully can provide a picture.
    It is a round steel male, female heavy steel punch.
  15. Sprcheese
    Sprcheese
    Great idea. Thanks for sharing. I was working on a similar idea for my project.
  16. JOECOOL
    JOECOOL
    way cool , nice tip
  17. HemiRambler
    HemiRambler
    Wow that looks SO MUCH BETTER than leaving them as punched!!! Nice tech!!
  18. 32SEDAN
    32SEDAN
    Nice method! You could use that on other pieces too. But won't holes in the visor defeat it's purpose?! :)
  19. river1
    river1
    cool tech!!
    bearings are still made in the usa? what brand do you work for?
    thanks
    later jim
  20. beaulieu
    beaulieu
    from So Cal
    the hole punch is called a greenlee punch ,
    I think you can get the smaller ones at Harbor Chinese freight
  21. Royalshifter
    Royalshifter
    Moderator
    Cool, simple tech is the best.
  22. Greenlee is a brand name, the technical name is 'knock out punch'. Greenlee will have the largest variety of them, but don't expect them to be cheap. The common sizes are for electrical conduit and come in sizes up to 4" conduit. They also make 'specialty' punches for electronics, with all sorts of odd shapes/sizes (even square ones). The cheap knock-offs aren't as good and don't last long on heavier gauge metal. Once you get above 2" conduit size, you really need the hydraulic ram setup for anything thicker than light sheetmetal.
