Quickchange gear set question
Discussion in 'The Hokey Ass Message Board' started by gasheat, Sep 8, 2010.
  1. gasheat
    gasheat
    from Dallas
    When looking at the gear sets that you can buy, several combinations have the same gear count, such as 21/21, 21/24,21/27, 21/29. Are all 21 count gears the same size? Is the 21 in a 21/24 gear set the same 21 in a 21/29 set? I need the voice of experience. Thanks.
  2. seb fontana
    seb fontana
    from ct
    Only the 21/21 gears are the same..All the rest will not enterchage anywheres as the gear pitch is different..The 21/29 has the smallest pitch which makes the 21 gear smaller in diameter allowing the 29 gear to fit..
  3. meengrinch
    meengrinch
    from ipswich ma
    i was told to never inter change them........and haven`t for about 40 yrs.....
  4. fab32
    fab32
    Each set is designed to accomplish the stated ratio. NEVER mix and match gears from one set to another even if the tooth count is the same. The diameters will be different thus causing interference or too much clearance. Get the gears from two sets with the same tooth count and compare the diameters and it will become apparent.
    Frank
  5. cracker head
    cracker head
    Oh, now you wanna change them.... ;)
  6. RichFox
    RichFox
    Actually there are some gear sets that come with 3 gears like set #30 and #31 that use a 20 and either a 40 or 41 tooth gear. And some other. But close togeather.
