Technical Quickchange Help...
Discussion in 'The Hokey Ass Message Board' started by brett4christ, Aug 5, 2016.
  1. brett4christ
    brett4christ
    Guys, need a little advice/help...
    I picked up this old Halibrand 201 a while back. Doing dis***embly, I'm trying to get the bearings out of the rear cover. The unit sat nose-up for years out in the elements, so there's a lot of corrosion on/in the bearings, to the point I barely got the cover off!
    So now, can someone advise me on the best way to get these bearings out??
  2. wbrw32
    wbrw32
    Put the rear cover plate in your wifes oven for a short time,,,Dont let her catch you tho
    volvobrynk and brett4christ like this.
  3. brett4christ
    brett4christ
    How long? What temp? I need the recipe!!
    OTOH, I guess I could use the grill?!?!
  4. alchemy
    alchemy
    Clean the grease and grime off the topside of the bearings, then wire brush the rust off the top edge of the outer race. Use your wire welder and run a bead around the inside edge of the outer race as far in as you can. This will shrink the race and hopefully make it smaller and easier to pull out. Might still need a puller with thin arms to get into the bearing center.
    brett4christ likes this.
  5. brett4christ
    brett4christ
  6. Marty Strode
    Marty Strode
    If you can find a used toaster oven (should be cheap @ Goodwill), place the cover (bearings down) and blocked up on both ends. Set the control @ 275 degrees, and the bearings should fall out. If not remove with a heavy glove, and slap the cover on a wood block, that should do the trick. Reverse the procedure to install the new bearings. IMG_6544.JPG
    Pewsplace and brett4christ like this.
  7. Bruce Lancaster
    Bruce Lancaster
    Something that will help in some situations like this is EvapoRust. I use it on things like Strombergs that are held together by rusty hardware so that the rust doesn't cut up the soft metal castings as screws and shafts are removed.
    I would really insist on that brand because I have proven for myself that it won't eat anything other than rust even in very long exposure. Degrease reasonably first so you don't contaminate the chemical and let it soak...it will eat away any rust it can touch without doing anything to the aluminum. It has some ability to get into tight places, not great but better than any acids I have tried...and of course the acids would destroy anything zinc or aluminum.
    thirtytwo and brett4christ like this.
  8. alchemy
    alchemy
    Yes Brett that's where I'd weld.
  9. seb fontana
    seb fontana
    from ct
  10. Bruce Lancaster
    Bruce Lancaster
    On the oven...if there is the slightest speck of old 90 or 140 in there, your house and your food will smell like a dead whale that washed up three weeks ago. Not just long enough to annoy your wife, forever! definitely use a junk toaster oven, outside on the longest cord you own.
    volvobrynk likes this.
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    You just gave away the trade secret. :eek:
    Always have a wooden block to slap stuff against!
    I used the wife's BRAND NEW oven to dis***emble my first Quckchange over 40 years ago. I have still that oven in my shop today.
    An expensive lesson.
  12. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Time for the "blue wrench" I have done these several times and on both aluminum and mag parts and always just light up the torch and run it around the area just out side of the bearing, get it up to 3-400 deg and bang it against a 2x4 and they will fall out. Let the cover cool and it will be just fine. Also when you put in new bearings do the same thing, heat the bearing bores with the torch, I use the rose bud head, and drop the new bearing in. DO NOT press the new bearings into a cold cover plate or for that matter into a cold case when you are changing the input shaft bearings. You will ruin the case.
    Rex
  13. flamedabone
    flamedabone
    I put the cover bearing side down about 8 inches off the floor in front of my shop torpedo heater. When the cover is the right temperature, the bearings will fall out.
    maybe a little tap on the backside....
    Good luck, -Abone.
