Quickie piston ring installation???
Discussion in 'The Hokey Ass Message Board' started by MyOldBuick, Jun 29, 2006.
  1. MyOldBuick
    MyOldBuick
    I'm working on a motor and I'm trying to get the jugs to slide over piston . . . piston rings are hanging me up. I can't slide the piston down , I have to put the jug down onto the piston/rings. All while holding piston straight, and whistling Dixie out my ass . . . ugh. I hate projects that have deadlines . . .
    Any hints, suggestions, or ammo? :mad:
  2. DrJ
    DrJ
    Jugs over pistons?
    Years ago I put a 914 engine together without the aid of a proper ring compressor that cam apart enough to get out from between the head studs so I invented a compressor out of a couple of wide radiator hose clamps.
    It was a PITA because I had to loosen and retighten it on top of each individual ring as the cylinder slid on but it worked.
  3. ray
    ray
    from colorado
    tried hose clamps? that what i use on my triumph sickle.
  4. jetmek
    jetmek
    back when i worked on g/a acft to change a jug i used a strip of aluminum wide enough to cover the rings and long enough to wrap all the way around the piston and had a tail bent up 90 deg on each end to squezze it together with vise grips. i kept the piston near the bottom of the stroke so the skirt would rest on the case to help stabilize it. hope that helps...
  5. Ol'Sarge
    Ol'Sarge
    I have used the hose clamp method many times. I cut an old oil bottle (plastic) to fit the piston size then use two clamps on the outside.
    Pretty cheap but effective.
  6. MyOldBuick
    MyOldBuick
    Cool -- great ideas! It was late, I'm in a rush . . . . no sense in screwing it up though. I'll just skip getting it done for this weekend. Many thanks!!!
  7. 77 rat
    77 rat
    from Louisiana
    When I was working on my engine I just went to Autozone and got the ring compressor from them for free on their "loan a tool" program. Paid the deposit took it home used it and brought it back and got my money back. Thats just a suggestion.
  8. MyOldBuick
    MyOldBuick
    Yea -- I should have got one when I was returning some crap yesterday . . . I should have also got some new plugs, since one of my old ones has piston goo on it . . . I guess I just had HUPA. (I don't know if they have a drug to cure that yet . . . )
