QuickTime 6020 Bellhousing
Discussion in 'Parts For Sale' started by 46Chief, Jul 7, 2023.
  1. 46Chief
    46Chief
    City: Los Angeles
    State: California
    Price: 600
    This bellhousing is designed for circle track, strip or street application. This bellhousing fits Small Block Chevy 265-400 CID & Big Block Chevy 396-454 CID engines to Muncie, Richmond, Chevy TKO, BW-T10. Fits 153 tooth flywheel and 10.5 in clutch. Is 6.29 in deep. Built from high grade steel, the cone is spun not stamped or rolled making this bellhousing dimensionally stable and accurate. Transmission bore is 4.685 in. This bellhousing weighs 18 pounds. Used for mock up only. Pickup W Los Angeles or shipping at cost. PayPal F&F or Zelle IMG_0235.jpeg IMG_0236.jpeg Note: Must use mini starter. Non S.F.I. approved.
    Features:
    • Quick Time Bellhousings are the most accurate bellhousings available due to our unique manufacturing processes
    • QuickTime cones are spun, not rolled or stamped. This allows Quick Time Bellhousings to be the most dimensionally stable Bellhousings available
    • Built from high grade steel – Work hardens to over 80,000 PSI strength. Over two times the strength of other steel bellhousings
    • 100% built in the USA
    • Patent on 16 points of Bellhousing Design & Process
  2. 46Chief
    46Chief
