Quik Welding Question
Discussion in 'The Hokey Ass Message Board' started by gold5000000, Apr 13, 2009.
  1. gold5000000
    gold5000000
    so i got this dvd from my uncle that came with his lincoln 110 and i was watching the basics on welding. They show a guy welding straight down a joint of 2 pieces of metal in the shape of an L. They said this was a good weld, i thought you were supposed to make circles so that the end result looked, as Jesse James would say, 'like a roll of pennys on an angle'. Just need a little clarity, Thanks
  2. red3
    red3
    I was taught to use a (j) motion it seems to work well for me.
  3. hotrod-Linkin
    hotrod-Linkin
    you are comparing 2 different welding systems and 2 different welding techniques. tig welding is way different in looks than mig welding. jesse does both but his welds will not look like stacked nickles with a mig.
  4. gold5000000
    gold5000000
    so straight across would be okay?, this is a change for me because people always told me how you should never do that
  5. Johnalias
    Johnalias
    from Cali
    the motions you use really depends on what your doing
  6. gold5000000
    gold5000000
    okay thanks, i just needed some type of clarification
  7. 64 DODGE 440
    64 DODGE 440
    from so cal
    That applies to more than welding.:D
  8. RAG66
    RAG66
    from WASHINGTON
    Concentrate on the technique of what makes the weld strong and the looks will come later. I don't know any welders young or old who always do perfect welds in appearance every time. It's not why you're joining two pieces of metal together. :cool:
  9. hoggyrubber
    hoggyrubber
    i have never seen people move a mig in small circles. i have seen people do that with arc welder to try to make the bead look better. not the same as zig zaging back and forth to fill in a large v if you don't want to make multiple p***es. i have only done a little tig so i'm not that versed in it.
  10. ttarver
    ttarver
    from austin
    ??? depends on your technique.:confused::confused::confused:
    mig weld "roll o' dimes"
    RMONTY likes this.
  11. Motorbreath
    Motorbreath
    small circles with a mig
  12. Mad~Max
    Mad~Max
    Just a note, that long beads aren't going to be done with a 110 welder, as they usually have a low duty cycle (on time versus off time). You can probably do an inch and then you have to let the welder cool down. It's a great welder for body panels and spot weld techniques called "connect the dots."
    I'm a zig-zagger, because I get paid by the hour :cool: Here's a picture of a typical second p***. Stacked pennies/dimes are for TIG and Torch where you dip the rod into a molten pool of hot metal.
    Here's a rainbow pattern for the last p*** (pause at the rainbow ends, go quicker through the middle).
  13. oj
    oj
    To get the roll of pennies look with a MIG there is a technique called either 's***ch' or 'penny s***ch' and it controls the on-off cycle of the weld. To create it you blast filler at higher than normal heat for very short time (1/2 second or so)then shut off and move ahead an 1/8 inch and repeat.
    Your machine probably dosn't have this feature but the higher amp models will. It'll look similiar to a tig weld, the nice feature about this technique is how you can control the heat.
    I wouldn't listen to jesse james.
    Dino 64, Just Gary and bigblk1177 like this.
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    If you are welding thin material.(sheet) You should not be weaving. Weaving is used to compensate for width as in a joint or when trying to fill a gap when washing out impurities from the puddle. The sheet metal joint should have a good fit with no or little gap and the weld speed and heat should be adjusted to simply stay in a straight line. The roll of dimes is a result of that perfect combination. The ripple effect of the molten weld causes this effect.
  15. Some of these replies are pretty crazy. Wow...
    Anyway....you oscillate back and forth in a J pattern. What you don't want to do is backwash the weld puddle your creating. This full power / part power to get a nice looking weld is rediculous.
    The above Rainbow weld for say....is actually a Weave Weld and that should be going uphill only....and is very prone for failure, compared to a normal weld just oscillating in a very short motion to place your fillet on both material pieces.
    Carl Hagan
  16. Shifty Shifterton
    Shifty Shifterton
    Motion entirely depends on gun/workpiece angle and where you're trying to direct the puddle/heat. But as noted, go crazy with the motion and suddenly you're moving the puddle back to freshly solidified weld that hasn't been slag brushed yet. Even clean looking MIG beads have slag/oxides. Sometimes though, those crazy beads are all you can do, and in many applications it's good enough.
    Good luck!
  17. speedmetal
    speedmetal
    from houston
    I use a whipping motion with mig. Back and forth I also with do circles just depends on position of weld.
  18. Nobodys Hero
    Nobodys Hero
    from New Jersey
    I agree...Small circles on a mig done correctly will result in good penetration along with the look of stacked nickles, pennies, quarters, silver dollars, subway tokens....whatever the saying is
  19. gold5000000
    gold5000000
    now i tryed the J and circle with my little Chicago 110, i cant get any real result though. I have solid wire, is that the promblem
  20. speedmetal
    speedmetal
    from houston
    You might be Running too hot/cold lots of variables. Show a pic
  21. gold5000000
    gold5000000
    it only has 2 settings, max and min i'll get a pic as soon as the camera charges a little
  22. gold5000000
    gold5000000
    another note, it is flux core, my mistake
  23. Special Ed
    Special Ed
    Them's som purdy welds!
  24. donzzilla
    donzzilla
    Everyones opinion is going to be different. Just because it looks good, don't mean it is good. Want to see a strong weld that has nothing to do with a stack of anything? Go over to your air compressor or oxy accetylene tanks and tell me what them welds look like. Smooth, flat and perfect penetration with maximum strength. Otherwise you'd be eating schrapnell from them flying apart. Moving a mig around makes excessive heat at the ends weakening the metal. If it is a tight seam with the proper portion v'ed out. There is no need for any movement from side to side. Just push 'er straight into the gas and let the sparks fly.
    JMHO,Zilla!
    oneratfink57 likes this.
  25. speedmetal
    speedmetal
    from houston
    Most bottles that hold compressed gases or air are done on a automatic welder and a positioner. The reason they are flat are for production reasons. They turn the osilator off otherwise it would take twice as long.
  26. Retro Jim
    Retro Jim
    Just make a good strong weld and let the grinder do the pretty stuff .
  27. punkabilly1306
    punkabilly1306
    from ohio
    wow, there are some interesting "answers" on here...I suggest you take a cl*** or get a book before taking some of these answers seriously
  28. Defisch
    Defisch
    from Hudson FL.
    I had a Chicago 110 mig and could never get it to weld good enough to trust it on something that needed to be strong, bought a Lincoln 110 and could not believe the differance.the Linc is awesome.
  29. Mad~Max
    Mad~Max
    No. Solid wire with an Argon/CO2 gas mix is what you want. Flux-core is for welding on your fence or wheel-barrow :p
  30. Mad~Max
    Mad~Max
    Whoa, this is not a structural welding technique. I would only use that on maybe a customized red wagon at the county fair.
    If anything, Jesse is a very good weldor. Subtract all the hollywood ****, and you're left with a man who welds pretty darn good.
