Technical R-12 to 134a
Discussion in 'The Hokey Ass Message Board' started by johnfin, Mar 29, 2025.
  1. johnfin
    johnfin
    from Florida
    I have seen some retrofit fittings for r-12 cars to allow 134a hose connections. When you screw those new fittings on do you have to remove the r-12 Schrader valves or does the new fitting depress the r-12 Schrader valve?
  2. squirrel
    what do the instructions say?
    (pretty sure you leave the valve in)
    firstinsteele likes this.
  3. pprather
    pprather
    My radiator-A/C guy handled the conversion for me.
    Sorry I don't have details.
  4. Boneyard51
    Boneyard51
    If your new adapter has a valve in it, you should remove the R-12 valve. You do not need two valves. But…..read the instructions!
    Bones
  5. johnfin
    johnfin
    from Florida
    I dont have a set, ie no instructions. Just saw them for sale and was thinking about the upgrade.
  6. Joe H
    Joe H
    The ones I have used screw on and operate the original valve, no need to remove them. This way you can remove the 134 adaptors to use on another system.
    fuzzface likes this.
  7. When I did mine 15 years ago I first drained the r12. Then i simply installed them over the r12 valves without removing schrader valves. I vacuumed the system for about 30 minutes and recharged to about 90% of the r12 capacity to compensate for the higher pressures. The a/c blew just as cold feeling the r12, no other components or oil was changed. I drove the vehicle for 12 years daily and never had any failures
    lothiandon1940 likes this.
  8. Exactly! An old time A/C man, still in business here, told me they started "converting" the "right " way . They learned, over time, to do just as you did.
    Ben
  9. gimpyshotrods
    gimpyshotrods
    Both versions exist.
