R&C artist's concepts/sketchpad renderings.....real life BUILDS??? TRUCKSTERS!
Discussion in 'The Hokey Ass Message Board' started by SinisterCustom, Jul 9, 2007.
  1. Anderson
    Anderson
    I couldn't help it....the kits with the right parts were just sitting there taunting me. Cory, your concept is awesome.
    anthony myrick likes this.
  2. jonzcustomshop
    jonzcustomshop
    fidgiter is that model truck finished? more pics...
  3. Ricola
    Ricola
    from MN
    What month is that issue? I looked for it after I had a chance to flip through a friends issue. Then I looked for it on the news stand but never found it.
  4. Conder
    Conder
  5. tjm73
    tjm73
    The issue came out in about June of July, which would make it a Sept or October issue I think. It's like a 3 page mini-article.
  6. fuzzface
    fuzzface
    It's the Aug 2007 issue. The concept trucksters they represented are: 1947-55 chevrolet 3100/3600,1958-60 D-100 Dodge truck,1960-66c-10,15,20,30,40, and a 1967-72 Ford F-100/250/350.
  7. joebuick
    joebuick
    im working on a 63 c-10 and i've got a 66 parts car i was planning on turning into a roadster the cab is ok but i figured it would be fine to chop up also it would be a good project to use up some of those parts ive been saving for a rainy day
  8. Anderson
    Anderson
    No, but it is in primer.
  9. Janne
    Janne
    I do lot photoshop work too for the same reasons, to get the shape as realistic as possible.
  10. SinisterCustom
    SinisterCustom
    Here is the beginning....in metal....18" out of the center and @ 6" off the bottom....still searching for a '60-'61 Chevy hood for the top of the cowl.....
    Started on the frame last weekend.
  11. jonzcustomshop
    jonzcustomshop
    here is the concept that sinister is going to build.
    I can't wait!
  12. SinisterCustom
    SinisterCustom
    Hahaha....I was trying to find my issue the other day....thanks for posting the concept Jon! I sent ya an E-mail @ the hoods.....
    A few "other" projects are about done, so I'll be getting the body back in the garage for more welding/grinding/carnage......
  13. rab71
    rab71
    Man that thing is awsome, it was my favorite one. I can't wait to sse it done!:cool:
  14. Stone
    Stone
    sweet model and concepts
  15. Appleseed
    Appleseed
    Kevin had Thom revisit the "truckster" in the March 08 (wow) issue of R & C. It has an exploded view aproach to these concepts. And he does the grill treatment a bit different using a 71 Ford cab and its grill and headlights rather than some thing like a 32 shell. Quite cool. I also thought of going Plowboy and use the rear end of a clapped out late 50s sedan rather than use a shorty bed.
  16. Danimal
    Danimal
    This rocks. I've got 4 '54 cabs around here. I NEED to do something like this at some point!
  17. Haywood
    Haywood
    from M'boro,TN
    Are you going to start a build up thread or keep us posted on this one? That was my favorite concept too. I would be very interested in seeing some one build it!
  18. SinisterCustom
    SinisterCustom
    I'll probably continue to post progress on this thread.....a fellow Hamber is sending me the hood "eyebrow" pieces (thanks Jon), so once I get those, progress will move at a faster pace than it has......:D Those pieces are crucial.
  19. Danimal
    Danimal
    What was on the cover of the August issue? I've dug through stacks of magazines and can't find mine!!
  20. R&C Lee
    R&C Lee
    from SoCal
    Subscriber cover was a black `32 3-window and Tudor hiboy. Newsstand was two `32s at Bonneville. The illustration in at the top right of both.
  21. Danimal
    Danimal
    Thanks for the info. Now I can at least get an idea of what to look for. I can't believe I've found all of them from 2005 to present EXCEPT August!
  22. R&C Lee
    R&C Lee
    from SoCal
    Unless I've missed something, the issue you should be looking for is 2007.
  23. These things may not be "Traditional Hot Rods" but they are very reminiscent of 60s show rods, I think the model Fidgeter is doing would make a very cool project. I wish I didn't have three other projects to finish. Damned short attention span!
  24. tjm73
    tjm73
    March 2008 issue has an expanded look at the idea.
  25. kustombuilder
    kustombuilder
    from Novi, MI
    i finaly started on that damn 54 ford cab tonight. :D i got it in the garage the other night and took some pics that i cut up to get the proportions i wanted. i took 8" out of it width wise and plan to section it about 6.5 or 7". i got it narrowed and clamped together tonight. we will see what the next few days bring as far as progress goes. i'm just gonna get the body together and sell it. i don't need another full on project and i could use the coin for other stuff (seeing as how i'm laid off now for a while). i might shorten and narrow up a 51 Chevy long bed box that i have out back and put it together with the 54 Ford cab. hell, i even have a 50 chevy truck frame with disc brakes on the stock I-beam axle. that might make a good low buck start for this thing.
  26. kustombuilder
    kustombuilder
    from Novi, MI
    a little more progress today. i got the two halves welded together (just tacked down the back side for now) and layed out the lines for the section. i also cut out the firewall. i did this in a strategic way. there is a method to my madness. you'll see later on in the build ;).
    i got the back of the cab sectioned 6.5" and tacked together at each end (door posts). still have to tack and weld it along the entire back side. that'll be a time consuming process there.
    the top of the back cab wall still has to be trimmed down. i haven't decided how far yet. after i get the doors sectioned and tacked on i'll decide on that. i'm going to tack weld the doors on since i did not get any hinges or latches wit this cab. whoever ends up finishing this thing can decide weather to weld the doors shut or locate hinges and make the doors swing. i would personaly hinge the doors but i have no intentions of finishing this one. i just want to build the body and then send it on to a good home.
  27. jonzcustomshop
    jonzcustomshop
    Any progress on this stuff?
    kustombuilder? sinister?
  28. kustombuilder
    kustombuilder
    from Novi, MI
    a little. no rush on this thing. it is just my "tinker with it when i don't feel like working on the other stuff" project. i have no intentions of "finishing" it. just do the body and sell it to someone who want to finish it up.
    i built the firewall a couple weeks ago at the same time i built the doors for my tube bender die storage cabinet. used GMgrunts Pullmax to do the beads and my buddy Dan's louver press to do the louvers in the doors.
    i've also started welding the driver door skin to the body. i cut the guts out of it and will do some bracing in there later so it will stand up to people putting thier weight on it as they climb in.
  29. fryguy
    fryguy
    Have you any updates on the progress of this build? I am been throwing ideas around ever since I read that article in R & C last year. Had too many projects at that time but I have since sold off a couple. Looking to do something with a 40 Ford truck cab that keeps calling my name.
    Would love to see how far you have gone as you are definitely doing it the right way reducing the width and sectioning the body. People tend to not go that route and the cab ends up looking like a baby Huey with a shirt tha just doesn't cover the body.
    Hope things are going well,
    Fryguy
  30. SinisterCustom
    SinisterCustom
    Same here:).......little progress, nothing worth showing yet, still working on proportions, may have to section it a bit more, width is @ right........
