Rack and Pinion on S10 clip??
Discussion in 'The Hokey Ass Message Board' started by fitzee, Jan 4, 2012.
  1. fitzee
    fitzee
    Now I know these are two topics not used alot here on this site!!but I am running into a number of issues with the steering box on the S10 clip in my fleetline.. looking for info on replacing it with a rack and pinion setup.I searched a few s10 sites but not much info other then what company to buy the rack from!! I looking to maybe use a late model Camaro rack.. anybody know of anybody that has done this??
  2. Hackerbilt
    Hackerbilt
    There were a few posts here that talked about it...but its difficult due to the inner pivots being very close together and getting a rack that narrow is pretty much impossible.
    If it was rear steer you could modify a Cavalier rack (center pivot design)...but of course it isn't.
    Rad tight is it?
  3. Hnstray
    Hnstray
    from Quincy, IL
    It's a question of geometry if you want it to handle properly. With the wheels straight ahead, the inner (rack end) tie rod pivots need to be on a line drawn through the inner "A" arm pivots of the upper and lower arms. Also, the height of the rack when mounted, and with the normal weight of the car resting on it's wheels, should be at a level that positions the tie rods at the same level/angle as the lower control arms.
    If you can find a front steer rack whose dimensions meet these criteria you can have a successful outcome. As you have been advised, there are places that sell racks dimensioned for this purpose. If you can't find a suitable stock rack, and can't or don't want to, spend the money for a properly setup rack, then you will only have two choices.....either don't convert to rack & pinion or install an improper rack and tolerate poor steering geometry and the resultant poor handling.
    Ray
  4. Hackerbilt
    Hackerbilt
    I have an idea fitz....but its late, I'm tired and its most likely dumb.
    If you don't come up with something tomorrow, we'll discuss it lunch time Friday at the "Island Bar & Grill"....
  5. Energy
    Energy
    You guys will have zman frothing at the mouth!
    rockable likes this.
  6. Hackerbilt
    Hackerbilt
    Naaa...we're not wat wodding! Hahaha
    Seriously though...IF it must be done it has to be done in such a way that proper geometry is retained.
    Neither of us is into making a mess...there are always other ways around an issue.
    This is a tough one, but thats what makes things interesting sometimes...
  7. kustoms36
    kustoms36
    i have a mustangII rack on my s10 frame,need infos contact me!!
  8. gimpyshotrods
    gimpyshotrods
  9. fitzee
    fitzee
    I put a number of racks in cars before.. so this is not new to me..I just tring to find out what racks work and if anybody has had trouble with racks in these frames.
    Bill yes I have trouble with fitting a rad in it ,my grill idea wont work as well as mounting a rad support..
  10. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    There's a guy here in town that I was doing some work for on his old cars who wanted me to put an S-10 clip under his '50 sedan delivery. I told him I wouldn't touch it and tried to talk him out of it cause of the problems you are describing. Well somebody had told him that it was the way to go. He finally got somebody else to weld the clip onto his frame. He spend a month or two trying to get the front sheet metal and radiator problems sorted out. It now sets back on an original frame.
    Not trying to burst your bubble here but I hope you and others will see that this is not the way to go on these old Chevys. I put a Camaro clip on a 50 F1 a while back and it just barely worked but made a great driver out of the truck so late model clips to have a place. Just not on these
    Here's where you can buy the rack for the s-10
    unisteer
    Karl Fields likes this.
  11. mrconcdid
    mrconcdid
    from Florida
    I'm courious, How did you shorten the rack.
    I have never taken one apart, so im just asking.
    I bought my power rack a napa around $160 with new tie rod ends.
    MrC.
  12. kustoms36
    kustoms36
    not me!!:) bought the 36 in running conditions....
  13. fitzee
    fitzee
    I new about these problems before I did this.. I did it cause the front end in mine was rusted out and his s10 was free!!
  14. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Free is always good, but sometimes its not as free as we wish.
  15. koolkemp
    koolkemp
    I can relate Fitzee I can make a 65 Mustang rad work but I am gonna try another rad I picked up recently in the 47....its even worse with the earlier style hood that comes to a point ...the other option is a manual box if you dont mind not having ps...when you get it figured out ya wanna come do mine ?! :D
  16. fitzee
    fitzee
    Steve My problem is i have the S10 frame raised up front and there is little room between the top of the box and the hood also I want to do a floating grill and the box is in the way of that. Doing lots of research on racks so we will see what i come up with..keep you posted..
  17. fitzee
    fitzee
    Your so right but if it was easy I would be board!! lol. Love tring to solve problems like this..
  18. studeboy
    studeboy
  19. MaxRevs
    MaxRevs
    Probably just a little late....but, www.unisteer.com has the conversion kits
  20. 52lomofo
    52lomofo
    fitzee i seen somewhere's cant remember where someone used a mid 80's dakota rack on a s10 clip
  21. koolkemp
    koolkemp
    He has it mocked up with a front drive mopar rack if I recall correctly, I think he started another thread, or its on the build thread for the Flatliner..
  22. Midget25
    Midget25
    I did a Speedway rack on my S-10 chassis under my 40 Ford pickup years ago, drives great. Just keep the steering links running as close to the same angle as the lower control arm as possible.
  23. which rack did you use as they offer a few. i'm trying to do a 38' ford truck with possible s-10 chassis and the box is in the way so how about some pictures that would really be killer!:D
  24. koolkemp
    koolkemp
    x2 !!
  25. kustoms36
    kustoms36
    s10 frame under my 36 3 windows with mustangII rack!
  26. kustoms36
    kustoms36
    pic of my 36 on s10 frame
  27. fitzee
    fitzee
    Yes i ended up with using a rack from a mid 90s dodge. works great. and you use all the s10 center link and tie rods. still need to fine tune it but it works good.
  28. fitzee
    fitzee
    did you shorten the rack?? I understand that the stock lenght rack will have problems with bump steer.
  29. kustoms36
    kustoms36
    yes my rack is shorten..the only negative side my turning radius is little short ...
  30. fitzee
    fitzee
    Thats what I found out when I looked up those racks for S10.. Now I havent got mine all figured out yet but so far it is working fine rolling around the shop.. we will see.lol
