1952-59 Ford rack&pinion
Discussion in 'Off Topic Hot Rods & Customs' started by raybug, Feb 26, 2012.
  1. raybug
    raybug
    hello just wondering if anybody has every put a manual or power steering rack in there 52 or 53 ford 2 door with factory front suspension any help would be greatley appreciated :)
  2. old lady's mad
    old lady's mad
    hey ray very hard to read when you use that font. gona sell your set up? might be intrested.
  3. 1 Ford fan
    1 Ford fan
    One thing I have heard is the turning radius is not as good as it should be...
  4. raybug
    raybug
    hey scott hit wrong ****on i think you can read this better. if i can find out what rack to use i will put it in or i may call fatman fab and just order a complete front stub and put a mustang 11 front suspeension in it ive got big plans for it even going to tub it and put a 5speed in it ofcorse you know it will be all ford. :D
  5. old lady's mad
    old lady's mad
    sounds cool. taurus racks are rear steer. most m2 kits are now using 82-88? t-bird racks which are front steer. and yes i can read it better now, lol. let me know about your current steering gear set up. most the rack kits you see for rear steers are using a cavalier rack
  6. parklane
    parklane
    Cavalier or Barreta rack is what to use. If you get the GT model, it's fewer turns lock to lock (quicker ratio)
  7. Retro Jim
    Retro Jim
    Anyone install one in a 55 yet ?
    Jim
  8. Crazy Legs
    Crazy Legs
    My dad (No Plan) & I just installed a cavalier powered rack on my 54 w/ air bags still using the stock a-arms/front stub, its not driveable yet but it seems to work. The exhaust outlets vs. the steering rod (shaft from column) is a beotch to get to fit though, but i'm running 2.5" tubes though
  9. parklane
    parklane
    Jim, doin one on my 56 wagon, and made my own mounts rather than buying them (dutch) With the Cavalier/Baretta rack, the ends are stationary, and the centre moves. Used the arm that goes from the box to the idler arm, and cut both ends off just outside of where thearms that go to the steering arm, and made up a piece of flat steel with holes at the proper spacing for the R&P, and welded it to centre . Hard to explain, but if you want, I'll take some pics and send them to you.
  10. Ole don
    Ole don
    I had a rack and pinion in my 55 JIm, and took it out and sold it and all the hardware. My car has Granada spindles. The rack may work well on a car with spindles that have steering arms that can be removed and shortened. The turn radius on my car was unacceptable. It took two cuts to get out of my own driveway.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. ctfortner
    ctfortner
    from West TN
    Man Jeff if I was just starting on my build I would be all over that kit at that price.
  13. old lady's mad
    old lady's mad
    man thats a deal.
  14. rld14
    rld14
    Wow, $850? Dang!!
  15. dwaynerz
    dwaynerz
    for 850, i think i could find the money to have it shipped.
